20 Most Recent Rockwell RK9000 Jawhorse Questions & Answers
did you try a lubricant on the threaded components ?
IE WD 40 or other lubricating chemical
Rockwell RK9000... | Answered on Oct 14, 2013
Type your model and brand into google then look for guard assembly.
Saws | Answered 13 hours ago
Probably melted some of the coil wires and the are starting to ground out.
http://www.manualsonline.com/
This site might have the manual you are looking for.
Could be any number of things. The electrical cord plug could be bad. A break in the cord wiring is a possibility. Check it over to make sure power is getting to the saw. The on/off switch could be bad. Do you hear a click when you switch it? The band motor could be worn. With the saw in the on position, tap the motor with a hammer.
Saws | Answered on Aug 01, 2020
Try searching online for owner's manual.most of time I find what I'm looking for,then either read then or download to read later. Good luck
Saws | Answered on Jul 28, 2020
is the blade locked ? like when you change tha blade...if not does motor hum when you trun on?
Saws | Answered on Jul 26, 2020
SINCE WE HAVE NO IDEA WHERE YOU BOUGHT IT SUGGEST YOU LOOK THERE FIRST
Saws | Answered on Jul 18, 2020
Contact Jura directly to inquire.
Saws | Answered on Jul 04, 2020
The saw is listed as a compound slide mitre saw and so I suggest you read the instruction leaflet, which might make more sense the second time...
Saws | Answered on Jun 06, 2020
The big question is which breaker does it trip?
If it trips the RCD it means current is escaping from the circuit to ground but if it trips the MCB it means too much current is being drawn and the circuit is overloaded.
The former would indicate an insulation breakdown while the latter could be a seized bearing or a serious motor fault.
The motor is presumably a brush-type for high performance in a light and compact package. The brush type motor is electrically very "noisy" and if not adequately suppressed it is perpetually trying to destroy itself and when such a motor succeeds it is usually marked by running slow, lots of sparking from the commutator and brush gear, consuming much more current and producing an entirely different sound. If it is left switched on it will rapidly overheat...
I think you need to take a peek inside.
Saws | Answered on May 31, 2020
Rockwell RK9000 Jawhorse Logo
1 questions posted
Top Rockwell Saws Experts
efs_perpends
efs_perpends
Tom Chichester
ray gallant
Are you a Rockwell Saw Expert? Answer questions, earn points and help others
View Most Popular
Rockwell Saws
  • Rockwell Saws
Most Popular Question
jawhorse left outside now locked up
  • Saws
