20 Most Recent Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N) Questions & Answers
i moved you out of HP,
the keyboard is bad. it seems.
get it fixed?
Lenovo ThinkPad... | Answered on Jan 22, 2018
Verify that TCP/IP (or other appropriate protocol) is properly installed.
  1. Open Control Panel and open Network Connections or Network and Sharing Center, then click Change adapter settings. The wireless card should be present as Wireless Network Connection.
  2. Right-click the appropriate Wireless Network Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) or Internet Protocol Version (TCP/IPv4) is installed.
  3. If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP.
  4. Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties.
Note: Only use a Static IP Address if your network/Service Provider requires one.
8.Verify the TCP/IP address.
  1. Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  2. Type the command, ipconfig. This will list the IP address for the local machine.
  3. If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands;
    ipconfig /release and then
    ipconfig /renew.
    You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address.
  4. Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway. (i.e. ping 192.168.1.1)
  5. If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.
  6. If you are connecting wirelessly, but receiving an IP address, your wireless router/Access Point might need to be reset (unplug power for a minute, then plug back in), or maybe defective. Please consult your wireless router/Access Point manufacturer for further assistance.
9. Ping the loopback address.
  • Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  • Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this:
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<10ms TTL=128
    Ping statistics for 127.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milliseconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
  • If instead, you receive errors, then there maybe system corruption or malware installed preventing networking from functioning properly.
  • 10. Verify that the hardware is functioning using diagnostics.
    • Check the web site, http://support.lenovo.com. Choose Download Drivers and Software and enter your particular system. Then under Diagnostic choose the download for your system. If diagnostics fail, please contact warranty support for resolution.
    • Run diagnostics for third party wireless card.
      Note: If using another manufacturer's product, then consult it's documentation on how to run the diagnostics for the wireless card.
Lenovo ThinkPad... | Answered on Apr 08, 2014
Hello. Did you reinstall Windows using the disc from Lenovo or was it an off-the-shelf/torrented version? If you contact the Lenovo support line they will be able to send you a disc with all your drivers. The support phone number is 1-866-96-THINK (1-866-968-4465).
Lenovo ThinkPad... | Answered on Sep 26, 2013
sound driver not work paraparly. so my halp you
Lenovo ThinkPad... | Answered on Sep 21, 2013
there is a wireless switch on the front of the notebook..try to switch it ON...
Lenovo ThinkPad... | Answered on Nov 10, 2012
make sure that you know the model of your motherboard and the chipset number. now connect to the internet and search for the driver of your motherboard. look for the chipset driver and install it on your pc. this will solve your problem.
A simple thanks is enough...
Lenovo ThinkPad... | Answered on Dec 24, 2011
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.
First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.
If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Lenovo ThinkPad... | Answered on Sep 28, 2011
Press function key+F6 then Wifi on
Lenovo ThinkPad... | Answered on Sep 25, 2011
Welcome to Fixya
Please click this link to download all the drivers of your R60 Thinkpad.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo ThinkPad... | Answered on Aug 07, 2011
Welcome to Fixya
Check the switch if it is at the ON position. The wireless switch is located either on the side or infront of the laptop. Try to enable the wireless LAN by pressing Fn + F6.
Lenovo ThinkPad... | Answered on Jul 02, 2011
ThinkPad The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Lenovo ThinkPad... | Answered on May 02, 2011
please update you service pack to service pack 3, i understand y to bour sistem is xp sp2?
Lenovo ThinkPad... | Answered on Mar 11, 2011
If you want to use Fn+F5 to enable the feature specified in IEEE standard 802.11, the following device drivers must be installed on the computer beforehand:
  • ThinkPad Power Management driver
  • OnScreen Display Utility
  • Wireless device drivers
OR you can follow this link:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-62714
Please rate this , if it works for you
Thanks
Sandeep
Lenovo ThinkPad... | Answered on Mar 09, 2011
2 things, did your Wi-Fi pci-card come with laptop or did you bought it later, if its the later it could be a authorizing issue, or else it could be the router misconfigured for the computer like the new routers with WPA2 protocols doesnt "seeing" the old b or g cards in laptops
Lenovo ThinkPad... | Answered on Mar 05, 2011
Welcome to Fixya
Make sure that all driver are installed. Especially the wireless LAN driver. Go to control panel then click on system then click device manager. Look for the network adapter category. There should be no exclamation mark to any of the devices listed there. You can download all your computer drivers here. If everything are ok then all you need to do is to go to control panel. Click network connection. Look for icon named Wireless then click on it. Search your router and connect to it.
Lenovo ThinkPad... | Answered on Jan 09, 2011
make sure that you're driver is compatible w/ you're device.
Lenovo ThinkPad... | Answered on Dec 16, 2010
place the mouse cursor over the bottom right screen, you will see an icon 2q==
select it and right click , go to OPEN NEWTORK .. i assume you have high speed modem thats linked to a a router -- select YOUR newtork name -- the others are surrounding neigbours that are close proximity to your network. you will have to know the password or key to enter
if you dont know that get in contact with your ISP and get them to help you connect
please post a positive feedback response for me
Lenovo ThinkPad... | Answered on Oct 17, 2010
Hi. I provided you a link where to download the drivers for your network card. Please click here.
Lenovo ThinkPad... | Answered on Sep 18, 2010
Really sorry that I can't help you with specific matters, but, take a look at this page, and check if one of those manuals have the informations you need.
Just my 2 cents...
Regards, Carlos
Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N) Logo
65 questions posted
Top Lenovo Computers & Internet Experts
Ekse
Toby Lee
Toby Lee
Sunny Solanki
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lenovo Computers & Internet
Most Popular Question
cannot get wifi using anatel 802 11 b g
  • Computers & Internet
