20 Most Recent
Hitachi Gst Hitachi UC24YJ 7-1/2-to-24-Volt Ni-Cad/Ni-Metal Universal Rapid Questions & Answers
My hitachi UC24YJ battery charger stopped working--no lights, no nothing
There is a fuse inside. The fuse plugs into a socket holder. The value I think is 7 amp. Verify it is good or replace with the value listed by the fuse holder. Also sometimes if the charger has an overload due to a bad battery, unplug the charger and wait about an hour then plug it in again, It might just start working
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
Clean grease off terracotta tiles
There are a couple of things you could try. I recently came across a specific grout/tile cleaner that works well. You can buy it online. It is a type of cream that you spread over the grease and leave for a while. After it has set, you can use a toothbrush (for best results) to scrub off the soap and grease. Otherwise, you can try magic eraser. Those can be used on tiles and get off a lot. Tiles make up such a great aspect of the house, I hope you can clean them up.
Elisa Jed '
http://www.herrmanntiles.net.au
12/2/2023 11:11:55 AM •
Saws
Answered
on Dec 02, 2023
