20 Most Recent Craftsman 5-1/2" Trim Saw, C3-19.2 Volt Cordless-g17 Questions & Answers
CAN i GET AN INSTRUCTION OR OWNERS MANUL FOR MY SAW
Go to Sears parts on line you should be able to get one there
5/23/2015 5:38:18 PM • Craftsman 5-1/2"... • Answered on May 23, 2015
Where can I get owners manual craftsman table saw model 137.248760
Try the distributor; https://www.searspartsdirect.com/manual/ooxr42sx59-000247/craftsman-137218760-table-saw-parts
1/1/2024 12:12:01 AM • Craftsman Saws • Answered on Jan 01, 2024
Craftsman model 137.212360. Repair of laser on 10 inch compound miter saw?
Question edited for clarity and spelling of maker. Question moved from Gardening. All parts are obsolete. You would have to take one from a newer model and make it work. https://www.google.com/search?q=Craftsman+model+137.212360+parts ..
10/26/2023 5:16:55 AM • Craftsman Saws • Answered on Oct 26, 2023
How to install drive belts on a craftsman table saw model # 218290?
Remove the side panel (key number 21) the dust cover (key number 23) guide holder (key number 29).
Use a 19MM or a 3/4 inch deep socket with a long extension and ratchet. This will keep your hand out of the way.
Now rotate the arbor counter clockwise and deflect the top edge of the belt downwards onto the arbor to catch the grooves.
Continue to work the belt around and checking at the motor shaft.
Once the belt is in place work it down by deflecting the top edge of the belt.
reference > http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-315218290/0247/0744600?pathTaken=&prst=0&shdMod=315218290
8/8/2023 7:21:48 PM • Craftsman Saws • Answered on Aug 08, 2023
How to remove the bearing #30571 on a Craftsman Radial Arm saw model 113.29003
Removing bearing #30571 on a Craftsman Radial Arm saw model 113.29003 can be a bit challenging, but it can be done with the right tools and techniques. Here are the steps you can take to remove the bearing:
  1. Unplug the saw from the power source.
  2. Use a wrench or pliers to loosen and remove the bolt or nut that holds the bearing in place.
  3. Carefully remove the bearing from the saw. If it is difficult to remove, you may need to use a bearing puller.
  4. Clean the bearing and the area around it with a clean rag or brush.
  5. Inspect the bearing for any damage or wear. If it is damaged or worn, it will need to be replaced.
  6. Once the bearing is removed, cleaned, and inspected, install the new bearing if needed, and reattach the bolt or nut to hold it in place.
  7. Before turning the saw back on, make sure to test the saw operation before using it.
It is important to mention that this is a general guide, the exact steps and tools may vary depending on the particular model, so you may want to consult your saw's manual or the manufacturer for more specific instructions. Also, be aware that working with any power tools can be dangerous, always use the appropriate safety gear and take caution.
1/28/2023 6:21:55 AM • Craftsman Saws • Answered on Jan 28, 2023
How modify pole saw blade
Saw blades are tempered steel and you would need to use good drill bits to get a clean hole. You also need to use a center punch to mark and start the hole.
7/11/2022 5:30:46 PM • Craftsman Saws • Answered on Jul 11, 2022
Where can I get a maunel for a craftsman model 923411 band saw circle cutter?
https://www.searspartsdirect.com/manual/5sf8b1mo8y-000247/craftsman-113243411-band-saw-parts
7/9/2022 2:28:34 AM • Craftsman Saws • Answered on Jul 09, 2022
2answers
I need to locate and purchase a replacement part form Craftsman Mitre saw. Part number 2VPR SUPPORT Can anyone help me?
I have found some hard to find items on EBAY and have posted on Craigslist wanted section to find needed items. Craigslist is more local so you might want to post in numerous cities or states. Good luck!
3/20/2022 9:23:01 PM • Craftsman Saws • Answered on Mar 20, 2022
2answers
Where can I acquire bearings for a 10 inch Craftsman table saw Model 113.298151
If you remove the old bearing, there will be a part number on it. Take that part number to your local bearing store for a replacement.
2/6/2022 7:15:59 PM • Craftsman Saws • Answered on Feb 06, 2022
The tensioner bolt on my craftsman direct drive scroll saw stripped out. What is the best way to fix it
Not sure what you mean by 'stopped out'? Ah edited to 'STRIPPED out'. That makes sense now.Home Depot have bins of bolts.
2/4/2022 6:03:59 PM • Craftsman Saws • Answered on Feb 04, 2022
Is there a replacement rip fence and blade guard available that will fit a Craftsman 10" table saw model 137.218072
The parts diagram for the Craftsman 137.218072 is available here: https://www.searspartsdirect.com/model/2fdac98m1p-000247/craftsman-137218072-table-saw-parts . The blade guard is available; it's part 3232, The rip fence (part 2RXS) is not available. However, there are after-market table saw fences that probably can work. You may need to make some adjustments for the mounting points. See https://woodsmithspirit.com/best-table-saw-fence/ for some ideas. I hope getting the blade guard at least helps. Cindy Wells
11/24/2021 1:55:33 AM • Craftsman Saws • Answered on Nov 24, 2021
Where can I find motor parts for a craftsman table saw model 137.248481
Using Sears parts direct, i could not find one part you listed. I suspect you have ruled out replacing the motor and finding the same table saw often for free on Craigslist.I see ereplacement parts has little inventory.ebay has brushes. Any brush for 137 series should fit.hope this helps some.
11/5/2021 9:01:48 PM • Craftsman Saws • Answered on Nov 05, 2021
2answers
Manual for craftsman table saw model # 315.27545
online sears.com or craftsman .com
9/15/2021 1:08:30 AM • Craftsman Saws • Answered on Sep 15, 2021
3answers
Can the rm871 motor be replaced with rm872 motor
ooooooooooooooooooo no plz dont try ur gona have to change ur car so much and spend morew money then your planing to
5/27/2021 3:27:53 PM • Craftsman Saws • Answered on May 27, 2021
Craftsman 5-1/2" Trim Saw, C3-19.2 Volt Cordless-g17 Logo
1 questions posted
Top Craftsman Saws Experts
Sean Wright
Sean Wright
john h
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Saws
  • Craftsman Saws
Most Popular Question
get instruction or owners manul saw
  • Saws
