20 Most Recent Opteka (OPT-42XHD2-S1IS) for Canon PowerShot S1 IS 0.42x (OPT42XHD2S1IS) Lens Converter Questions & Answers
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Opteka... • Answered on Sep 11, 2010
http://opteka.com/contact-us.aspx copy the above address into your browser's address window for service inquireies
Opteka Cameras • Answered on Feb 24, 2018
Contact your Opteka dealer for parts. Whoever sold it to you should have them.
Opteka Cameras • Answered on Oct 21, 2014
When you go to the Opteka page here http://opteka.com/500m.aspx You can select "options" for the camera company (there are 6) which you have. It may mean that the lens uses an adapter for the different pin and thread patterns, so the lens if bought new will fit with the selected option, a used one, you may need to get an adapter. Best bet is to try before you buy.
Opteka Cameras • Answered on Apr 11, 2014
once deleted, they are gone. unless you have a model that allows recovery, but, since you didn't tell us make, model and age - as well as how long ago you deleted the photos, it could be a problem to try to guide you on how to recover them.
Cameras • Answered on Apr 29, 2021
Follow the steps below and check if the issue is resolved. Step 1: Open control panel by typing Control Panel in the search box next to Start button, and press Enter. Step 2: Select Large icons in the view by option on the left top hand side of the window, and select File Explorer Options. Step 3: Click on View tab and check if Display file icon on thumbnails Show preview handlers in preview pane, are checked. Step 4: Uncheck Always show icons, never thumbnails Always show menu Step 5: Enable or disable any other options you wish to make changes on, click on Apply, and OK. Hope this helps! However, if this method fails, check out this article: 3 Simple Ways To Fix Photos Cannot Preview Or Open Error On Windows
Cameras • Answered on Apr 27, 2021
This is not actually a camera query. However - have you run the head-cleaning / head adjustment utilities ?
Cameras • Answered on Apr 24, 2021
If you have unwanted photos or videos, delete them using the Android app.
  1. Open Amazon Photos.
  2. Press and hold the photo until a check mark appears.
  3. If you want to select more photos or videos, tap once on each additional one. ...
  4. From the three dots icon, tap Move to Trash.
  5. Select: ...
  6. Tap Move to Trash.
Amazon.com Help: Delete Photos and Videos Using the ...
Cameras • Answered on Apr 21, 2021
No info generic answer test batteries new doesn't mean free from defects also check contacts are not corroded if problem persists then internal circuit problem
Cameras • Answered on Apr 20, 2021
perhaps in the main menu ?
Cameras • Answered on Apr 16, 2021
There will be a method within the main menu ... if it has one.
Cameras • Answered on Apr 12, 2021
check with the official amcrest website and not one advertising services here at fixya. they do not sell the product
Foscam Security Camera Image Problems- Foscam Troubleshooting. Call for service +1 530-455-9293 Foscam security cameras are quite renowned for several purposes, such as its features, design, quality service, foscam cloud, application, and foscam support services. These are some of the exceptional things which make these security cameras of foscam world famous. Unfortunately, these technically advanced cameras also face certain physical and technical defaults, and one such problem is foscam security camera image problems. While we are on the same topic, here are some of the main image related issues that may happen with your camera: ?Power supply issues will cause rolling lines in the videos. ?The error of IR cut filters will enable the facility of outdoor visibility. ?Troubles with video encoding systems that could disappoint you with poor quality videos. ?Ground locks will create horizontal lines on your recorded videos of the foscam camera. ?The infrared glare of the camera will create eaves in the camera image/video. Here there is nothing to worry about if you are also facing any of the above image problems with your foscam camera because our foscamcamera support service will always help you fix every variety of foscam camera issues without much effort. So whenever you are facing any variety of problems with your foscam camera, call us directly on our Foscam technical support numberor interact with our employees on the live chat section. Once you file your complaint with us, we will visit your place and fix your camera instantly. https://foscam-support.com/best-foscam-security-camera-for-you/
Cameras • Answered on Apr 07, 2021
I use Duplicate File Detective to accomplish removing duplicate photos from my PC but there are many out there and many for free. I just have the program search based on image file extensions only, (.CR2, JPG, DNG).
memory cards do go bad just as do all things made by man
Cameras • Answered on Apr 06, 2021
Opteka (OPT-42XHD2-S1IS) for Canon PowerShot S1 IS 0.42x (OPT42XHD2S1IS) Lens Converter Logo
1 questions posted
Top Opteka Cameras Experts
ADMIN Canada
ADMIN Canada
Are you an Opteka Camera Expert? Answer questions, earn points and help others
View Most Popular
Opteka Cameras
  • Opteka Cameras
Most Popular Question
canon s1is lens error restart camera
  • Cameras
