20 Most Recent Wells F-686 Deep Fryer Questions & Answers
Is the oil coll and it still doesnt reset?If so the hi limit is bad,which is the reset.If you gain acess to it you will see 2 wires.Connect these wires and it should heat.HOWEVER this is a saftey device that prevents the oil from getting too hot and catching on fire.
Wells F-686 Deep... | Answered on Mar 22, 2009
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
Wells F-686 Deep... | Answered on Jun 03, 2008
It is not economical nor even possible to convert electric fryer to gas fryer since the tank construction and parts are very different.
Wells Kitchen... | Answered on May 20, 2015
Wells Fryer manuals can be downloaded free at www.wells-bloomfield.com
Any competent service technician could cobble something like this together, but I'd challenge the insurance company, as this fryer is UL approved. Such a modification would be expensive and void the warranty and NSF and UL approveals.
Wells Kitchen... | Answered on Sep 23, 2014
Hi there! If hi limit wont reset when button is pushed, there might be a mechanical problem inside the part which prevents t from resetting, you have to replace the part.
Visit www.middleby.com and select wells to find the nearest authorized parts dealer near your area.
Regards.
Wells Kitchen... | Answered on Jan 28, 2013
check your program for the basket lift, also check the mechanisms.
Wells Kitchen... | Answered on Mar 31, 2011
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
Wells Kitchen... | Answered on Nov 23, 2010
By purchasing a natural to propane conversion kit & it also might require the burner orfices to be changed out too. By contacting [email protected] 888-492-2782 with your model & serial # in front of you, they will be able to give you the part #s needed. If they will not sell you the parts then you can probably purchase them from Stove Parts Supply in Ft. Worth Texas
Wells Kitchen... | Answered on Jul 25, 2009
I also need a repair manual for Med active Ultrasonic Humidifier, or source of spares.. Any help please?
Nigel
[email protected]
Kitchen... | Answered 20 hours ago
Wells F-686 Deep Fryer Logo
2 questions posted
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Wells Kitchen Appliances - Others
Most Popular Question
wells deep fryer heat
  • Kitchen Appliances - Others
