20 Most Recent
Legacy LDTSN7 Car Video Player Questions & Answers
I just bought a car which had this dvd player in
If the clock settinga nd the panel display seems right then we will check on the dvd side. However of the all the lights/display are coming on , not showing any response to the panel then you have a failure of the microprocessor. If not check to clean your head after opening of the set, then insert and watch if the dvd is taken in , played, disc on rotation and read. If not check for transport system, motr failue, link failure, mechanism jammed then if no rotation check for failure of the optical head . replace if you have cleaned the head and checked for any foreign particles. check this out. Good day
My legacy indash DVD player
CONNECT YOUR BRAKE SENSE WIRE UP TO THE EMERGENCY BRAKE SWITCH LOCATED ON THE PEDAL, THEN ENGAGE THE BRAKE WALA!! IT PLAYS!
You should have a wire on the harness labeled Parking Brake (or similar). This wire needs to be connected at the parking brake....or to a toggle switch. It needs to sense a ground after the radio is powered on in order to play DVDs.
Eject
Try Pressing the power button and the eject button at the same time.
Cant open mp3 files
When folder icon displayed on the screen it means it has subfolders,press enter and you can go in to the sub folder
please see the attached image
all the best
sreejith
Legacy LSW127 rms rating?
4000 watt amp that was 2-channel with 2000 watts peak and 1000 watts RMS per channel, when wired as 4-ohm, which is what the sub's ratings are based on. therefore the amp and sub configuration were a perfect match, however approximately 1/2 an hour into driving with them i noticed a plastic/rubber burning smell and immediately shut off power to them. upon inspection both subs were blown and completely unusable. this leads to the conclusion that they were poorly rated and of poor quality materials, and i hereby advise that unless your going to run way under the limits, they are no good!
What ar the specs for a legacy LA420 600 w amp
This Legacy LA 420 amplifier features 400 watts of power, two channels (bridgeable), a two-way crossover, Mosfet power, 2 ohms stable, and THD less than 0.04%. The amplifier measures 10" x 9.5" x 2.75".
