20 Most Recent Miele 36 in. KM3474 Gas Cooktop Questions & Answers
CAN YOU GET THE GLASS
Hi anina266,
It comes with the trimming unfortunately.
Part number: 23022302
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
8/17/2011 4:50:23 PM • Miele 36 in.... • Answered on Aug 17, 2011
2answers
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
4/4/2011 3:50:09 AM • Miele 36 in.... • Answered on Apr 04, 2011
I have looked all the site for MIELE parts, but
you can only purchase Miele parts from Miele and no one else other than authorized Miele service agents and it is the same price. you would also have to call them as parts are not on line
8/19/2010 9:33:04 AM • Miele 36 in.... • Answered on Aug 19, 2010
Hi I have a Miele KM5676 cooktop. I'm getting a FE error.
It is a generic hardware error and should contain a number which pinpoints the fault. You will likely need a service call. https://www.google.com/search?q=Miele+KM5676+cooktop.+FE+error ..
10/19/2022 10:48:19 PM • Miele Cooktops • Answered on Oct 19, 2022
Miele HR1124 cooktop - turning one burner on keeps igniter clicking for all 4 burners.
It is a gas appliance and it is a Miele, so you need a registered gas technician to service it. In my experience, the spark igniters work on all burners. To clean the burners, remove them all and put them in a large saucepan. Add cold water and dish liquid, bring slowly to a simmer and turn off. When cold, rinse and scrub with a plastic pot brush, paying particular attention to holes and slots. This was a job we did in the restaurant every week. It is a good plan to do before you go to bed for the least disruption. The product specs says; Automatic re-ignitionSealed burners • M Pro Dual Stacked Burner System So perhaps my hack won't work if they aren't removable. I found this video :>) https://blog.yaleappliance.com/new-miele-hr1124-30-inch-professional-gas-range ..
2/19/2022 5:43:34 PM • Miele Cooktops • Answered on Feb 19, 2022
2answers
We can not turn on stays locked ;we have an Miele induction cook top
https://www.coolblue.nl/en/advice/errors-miele-induction-cooktops.html How do I unlock my Miele cooktop? Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time. Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time. If this doesn't unlock when you do this then you have a problem with the control board.
11/17/2021 11:18:00 AM • Miele Cooktops • Answered on Nov 17, 2021
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
6/26/2021 2:41:16 PM • Miele Cooktops • Answered on Jun 26, 2021
I have a Miele induction cook top flashing E80
That will not matter
1/5/2020 7:15:33 AM • Miele Cooktops • Answered on Jan 05, 2020
2answers
Miele induction stovetop dE error?
Miele cooktop induction KM 6350, 6380, 6382, 6383 dE mode
How to switch off demonstration mode
Press ‘power’ button on front and ‘lock’ bottom at same time until you get p5 mode displaying ( it is in programming) mode.
Then press top left to ‘0’, bottom left panel to ‘0’, then press right bottom panel to 9, then press on ‘power’ button to save. This should take it off demonstration mode.
6/7/2019 4:59:14 AM • Miele Cooktops • Answered on Jun 07, 2019
2answers
2answers
What does dE mean on miele induction cooktop?
Most likely Door error
11/20/2018 6:25:57 PM • Miele Cooktops • Answered on Nov 20, 2018
Need repair of vent/fan on Miele gas cooktop. Zip is 04107
fixya doesnt send service personal notify a service repair company in your area
11/4/2018 3:26:28 PM • Miele Cooktops • Answered on Nov 04, 2018
Miele induction stovetop dE error? the stove will not heat up
Wrong pan
5/16/2018 12:32:28 AM • Miele Cooktops • Answered on May 16, 2018
Miele 36 in. KM3474 Gas Cooktop Logo
6 questions posted
Top Miele Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Miele Cooktops
  • Miele Cooktops
Most Popular Question
get glass
  • Cooktops
