20 Most Recent Sunbeam SCA103RWB1 Room Air Conditioner Questions & Answers
Unfortunately probably 50% of the aftermarket outdoor fan motors that I have installed squeal. Give it a couple days, noise should subside.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sunbeam... | Answered on Mar 19, 2017
Go to your local hardware store go down the aisle where they have the new window A/C units and BUY A NEW ONE!!
Sunbeam... | Answered on Aug 19, 2011
Hi
EE error reminds you to clean the filter, to clean it turn the unit off and unplug it, then clean the filter completely. After cleaning if the issue returns then replace the filter. Hope this helps...please post back for further assistance.
Daniel
Sunbeam... | Answered on May 26, 2011
hello. i can help you.
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
  • Wiring (Inspect for any broken or burnt wiring)
  • Thermostat
  • Compressor
  • Overload and/or relay
  • Selector switch
  • Control board
Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
From the following website you can download a manual that will give you all the dimensions and installation specifics you need.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Sunbeam... | Answered on Apr 13, 2011
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Sunbeam... | Answered on Jun 02, 2010
-Check the setting of your temperature.
-Check if the timer is not set.
-Check if no restriction in your outdoor or indoor and outdoor are both clean.
-Check if no error code (flashing light) at the indoor.
Sunbeam... | Answered on Jan 07, 2008
Blanket, control, or both defective
Sunbeam Heating... | Answered on Aug 23, 2020
then it is time to bin it and get new one no one fixes the wires that break in them
Sunbeam Heating... | Answered on Feb 18, 2020
never cover an electric blanket with anything. use it as a blanket above you only. read the instructions please for your safety
Sunbeam Heating... | Answered on Dec 22, 2019
Generally means u have a bad connection at the wall or at the control module. Disconnect everywhere u can and reconnect
Sunbeam Heating... | Answered on Sep 09, 2019
Try unplugging the power cord from the wall socket and check that the connection to the blanket is good and not loose. Then plug back into the wall socket and switch on. If error still occurs then there may be a problem with the blanket.
Sunbeam Heating... | Answered on May 17, 2019
Probably means the pad has failed and will have to be replaced
Sunbeam Heating... | Answered on Feb 05, 2019
Sunbeam SCA103RWB1 Room Air Conditioner Logo
Popular Tags
20 questions posted
Top Sunbeam Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Sunbeam Heating & Cooling
Most Popular Question
sunbeam model no sck 14200 dr no
  • Heating & Cooling
