20 Most Recent
JVC AV48P777 Television Questions & Answers
Power board has been replaced with a new one.
Hi jblake4900,First, please double check if the part/board no. (
SSR-9010A-M2) is the same as the original one. If yes, then other parts gone bad also aside from the power supply board. This is caused by faulty convergence chips (
STK394-250) on the deflection board (part no.
SSR-2510A-M2). Your unit used two convergence chips that is mounted on the large aluminum heat sink behind the flyback transformer.I would advice you to replace both the convergence chip.You need to prepare the following :1. Necessary tools and test instrument2. Soldering Iron3. Desoldering pump4. soldering lead5.
Thermal paste.6. 2 pcs
STK394-250Soldering TutorialHow to desolder parts on the boardLet the unit unplug from the outlet at least 1 hour to drain the voltages from the power supply board. Familiarize all connectors (take a picture of it if necessary to guide you replacing the connectors). Please let me know if you need further assistance.Hope I helped you.Have a nice day!Jdvillanueva
I have a JVC 48"
Yes, you must clean the unit from dust using an air blower and soft bristle paint brush. Do it gently, don't give pressure on the parts to avoid solder joints to crack and create new problem.
Check the power supply board's fuse, you have mentioned that the main fuse is intact, check the other fuse near the voltage regulator IC (STR IC that mounted on the heat sink). Let me know its status to assist you further.
Jdvillanueva
Blinking powerlight on front when i try to turn on tv
This is more likely a power supply failure. Most causes of tv failure are due to bad capacitors on either a system board or the power supply. In this case, it sounds like the power supply. You can test the capacitors with a capacitor tester to determine faulty capacitor. You can also test other components like power supply current with voltmeter or mulit-tester.
Jvc AV-48p777 turn on goes right back off thin
The power suply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Had tv for 4 years very well kept and now it wont
You can try to unplug and then plug it back in and see what it does. If you just hear one loud snap when it went out and not more noises, then its likely your Horizontal Output transistor that shorted out. I've seen one that just needed to be resoldered, it was soldered too close and ARCed causing the snap and shutdown, then it was shorted but just temporarily. If you plug it back in and then it thumps over and over, then you have a short somewhere, usually on the 210 volt line (video output ICs) or on the +-24volt line (convergence ICs)
let me know more info and we can diagnose if for sure. almost all repairs will require some soldering/disassembly skills, but depending, it could be easy.
No sound or input
You have the center sound on in your menu, just turn off the cneter sound option and it will all come back on
I have a model av48p776 jvc I am getting jitter
JVC AV48P776 Jitter and Brightness Varies
Check for convergence failure.
Convergence Gallery Try adjusting convergence in user menu. If convergence display is messed up or adjustments do not work correctly, you have an Intermittent short circuit within an STK IC.
Look at menu screen with an unused input (antenna or video). If menu is stable and clear, TV may be OK and you may have a signal input problem.
If it is not poor quality input signal or convergence problem, someone has to troubleshoot to determine if it is a Video, Processing, Power supply or CRT related problem.
Most likely convergence.
easyab
My JVC AV-48P777 wont turn on. Opened it up and
The first real question is does the power light on the front of the set come on and just blink?
If blinking power light you proceed one way, if no power light you approach it in a different way.
SD TECH
MY JVC AV 48p777 wont turn on.
Yes unplug the TV for 5 minutes and hold the menu button down while powering it up for 1 minute then release the button and press volume up 6 times followed by down volume key 4 times.
Let me know if it works
I need to know what
6 knobs piece is called Focus Block and it is necessary part of rear projection TV that has 3 picture tubes to project picture on front screen.
Tuner part is covered with metal shields and usually has one Antenna In pin.
Click
Focus Block to see an image (for reference only)
Click
Tuner for its image, as reference.
Thanks.
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
- Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
- Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
- Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
- Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
- Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
