20 Most Recent
Krups FBC1 1600 Watts Toaster Oven with Convection Cooking Questions & Answers
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
My Krups FBC 1 toaster
Most of the time a hardware store will have a variety of springs or try home depot.
That's if you only don't want to wait for a manufactors spring.
My krups stop working while
Make sure you have AC at the wall-plug by plugging in another appliance there. If not, you may have a tripped GFI (Ground Fault Interrupter).
If power is there, a thermal fuse, now common in many 'hot' appliances, may have failed.
These are almost all made in China now and have proven very unreliable; you may just be another victim of this.
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
