20 Most Recent Amana LWA40A Questions & Answers
Sounds like a timmer to me.. got a couple bad cycles too bad its the main cycle
Amana LWA40A • Answered on Aug 30, 2019
The agitator will just pop off with enough working with it. There are no screws that hold it in place. Just some slight prying and some wiggling and it will come off. They are on there pretty solid so just work with it
Amana LWA40A • Answered on Jun 01, 2010
I had the same issue last year on y lwa50aw. It is the timer. Get the speedqueen version it is about $50 -$80 and aboyt 15 minutes to replace.
Amana LWA40A • Answered on Apr 26, 2010
this is a no drain error or slow drain issue you need to check for anything that would or is restricting the water from draining out of the tub.
if the water will not srin then you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then check all your hose to and from the drain pump
Amana LWA40A • Answered on Apr 13, 2010
I bet you ain't got that dang belt routed right. I have a topslosher bonified repair manual for you:
AMANA TOPSLOSHER
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Amana LWA40A • Answered on Mar 17, 2010
Thank You for contacting Fixya.com
Inorder to fix the agitator I would request you to please follow the step by step troubleshooting mentioned in the bellow mentioned link:
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Have a nice day.
GodBlessU
Amana LWA40A • Answered on Sep 10, 2009
without really looking at it i would have to say it Sounds like water seal gone in drum. If back of drum at the bottom is wet with black or dark run stains this is the problem.
Good luck
John
Amana LWA40A • Answered on Sep 03, 2009
Hi, there are two screws at the bottom of the front panel. THis should release the panel by ulling the bottom toward you. Let me know if I can assist you further.
Thanks
Vic
Amana LWA40A • Answered on May 16, 2009
Probable gear box fault Regards Engineer
Amana LWA40A • Answered on Apr 25, 2009
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Amana LWA40A • Answered on Jan 26, 2009
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Amana LWA40A • Answered on Jun 21, 2008
Remove the front panel, two screws on bottom. On the bottom of the motor is a white colored pump, if the water is coming from there you need to replace the pump. you can find this part on line, just google Amana washer parts.
Let me know ifyou have any more questions.
Amana LWA40A • Answered on May 25, 2008
Take front of washer .. get light and look for leak and listen to find out where noise is comeing from
Amana LWA40A • Answered on Dec 09, 2007
The pull at the bottom of transmission should turn both ways.. one way for spin the other way for agitate... if transmission turns both ways means not locked up and probley bad motor..
Amana LWA40A • Answered on Sep 05, 2007
My Amana washer is stuck on rinse
Amana Washing... • Answered on Mar 25, 2021
Go onto https://www.manualslib.com/products/amana-washer-3421639.html an they have a free manual. This should help you. Thank you and wouldn't mind a follow. Have a great day. Przemek
Amana Washing... • Answered on Feb 23, 2021
Washing Machines Logo
23 questions posted
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
amana washer lwa50aw
  • Washing Machines
