20 Most Recent
Wells F-85 Deep Fryer Questions & Answers
Wells electric fryer model f-67 wont reset
Hi there! If hi limit wont reset when button is pushed, there might be a mechanical problem inside the part which prevents t from resetting, you have to replace the part.Visit www.middleby.com and select wells to find the nearest authorized parts dealer near your area.Regards.
Hi I believe I have
Running the fryer with no oil will over heat the coil very quickly...this caused the element to burn out...
That element will be replaceable...
If you call these guys you should be able to purchase a new element from them...
http://www.fryerworld.com/wells-f49.html
heatman101
Model FGS-40 Ser Fe 1959 How do I change it from
By purchasing a natural to propane conversion kit & it also might require the burner orfices to be changed out too. By contacting Wells@ 888-492-2782 with your model & serial # in front of you, they will be able to give you the part #s needed. If they will not sell you the parts then you can probably purchase them from Stove Parts Supply in Ft. Worth Texas
