20 Most Recent Hobart SR24C-4 Dishwasher Questions & Answers
I have a single tank
Curtains aren't there for air circ, their purpose is to keep tanks separated and help with temp control. If things are coming out wet this can be to do with rinse aid setting. Is there a dryer fitted to this machine?
1/6/2018 9:38:51 PM • Hobart SR24C-4... • Answered on Jan 06, 2018
0answers
Not pumping at end of cycle
Cancell all the pre- set programs. refer user guide. Restart after switching OFF and try.
Still problem continues, only option to reset the system board. This procedure is known to the manufactures service provider. You have to get the sequence from them.
5/28/2010 4:46:48 AM • Hobart SR24C-4... • Answered on May 28, 2010
Hobart dishwasher Am14, rinse cycle is too short.
no rinse time can't be adjust on the am-14 modelit is built in main board non variable
1/11/2010 1:32:16 AM • Hobart SR24C-4... • Answered on Jan 11, 2010
3answers
We need a low sudsing powdered dish washing detergent
eco-lab solid power
11/12/2009 1:21:12 PM • Hobart SR24C-4... • Answered on Nov 12, 2009
Hobart AM 14 or AM 14 C
8/22/2009 12:40:35 AM • Hobart SR24C-4... • Answered on Aug 22, 2009
I am looking for a
Hello
Please click on the following website link to locate the nearest dealer near your location to order the replacement chlorine supply tube. http://www.hobartcorp.com/salesdirectory/foodservicedealer
Let me know how this turns out.
Benjamin
7/21/2009 1:21:48 AM • Hobart SR24C-4... • Answered on Jul 21, 2009
Dish washer beeps all the time
Are there there any codes displayed or a wrench icon on the display?Can you give more info of when the problem started?
3/22/2009 2:28:21 PM • Hobart SR24C-4... • Answered on Mar 22, 2009
3answers
Where do I get a lower door gasket for a Hobart SR24C dishwasher?
Goto to this site http://www.hobartcorp.com/default.aspx.Find a office near you and you can order the part.
5/20/2008 8:13:29 PM • Hobart SR24C-4... • Answered on May 20, 2008
Hobart SR24C-4 Dishwasher can't drain completely
If this is a new occurance, and not "since it was installed", it may be the drain impellor. Little fins on top of the impellor sometimes get worn off. It is under the lower wash arm in the pump housing. The only trick to taking the pump apart is not loosing any of the shims.
Go to page 12.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/860F7951C087BD7F85256D36004978EA/$File/F43078.pdf
Also, (and most likely if the unit looses water during the wash cycle), any obstruction to the drain valve can cause it to not drain proper. The drain valve uses a little flapper valve to drain the unit. It has a rubber stopper that needs to properly close. The drain valve is at the front of the unit with a red coil and white plastic body. It needs to be closely inspected. (page 22)
If this is a problem since it has been installed, it is likely due to the running of the external drain line. (Too high)
5/10/2008 12:24:09 PM • Hobart SR24C-4... • Answered on May 10, 2008
Hobart AM15-1 Low Temperature Dishwasher. Techs question. I just replaced main board and relay board but now getting a E1 error code, curious if anyone knows what it is?
Question edited for clarity. Error codes should be on the rear label according to the Technical Manual https://www.partstown.ca/modelManual/HOB-AM15T_spm.pdf There is no E1 error code for that machine and is is suggested that the display may be faulty. https://www.google.com/search?q=hobart+am15+e1+error+code The only reference to E1 is here, for the AM-16 and an electrical 'type'. https://www.hobart.ca/wp-content/uploads/pdfs/warewash/AM16-BAS-Base-Electric-CF48568.pdf For LXi machines Drain and fill error messages are displayed as E0, E1, E2, E3, E4, E5, E6 or E7. In all cases, the dishwasher will terminate current cycle operations, turn off all heat sources and display the message until the OFF button is pressed. (A power drain will not occur when turned off.) (See Troubleshooting.) If problem persists, contact your local Hobart Service Office Phone Hobart Support. there are no Hobart Techs here, just me as caterer, career long Hobart user and Expert finder of information. Or try JustAnswer dot com. ..
4/16/2024 5:19:38 PM • Hobart... • Answered on Apr 16, 2024
Problem on hobart ecomax 602-10
1/4/2024 2:04:53 PM • Hobart... • Answered on Jan 04, 2024
Hobart Dishwasher CL44E showing display PROBE ERROR-WSH PW DR.
To me the Error is telling you Probe Error - Wash - Power - Drain CL & CLe Series Dishwasher Display Codes Below are common codes that display on Hobart CL and Cle Series Dishwashers:
  • Door(s) Open - This displays if one or both doors are open. Close all inspection doors.
  • Clear Conveyor Jam - The code appears if there is a jam. Remove the rack from the machine. Then, press START and rerun the rack.
  • Probe Err - TANK - Check if the lower float assembly in the displayed tank isn't visibly damaged and that the proper amount of water is covering the lower float in the tank.
  • Probe Error - FnlRns - Make sure the supply water valve to the rinse booster is open.
More here and a video https://www.google.com/search?q=Hobart+PROBE+ERROR-WASH+PW+DR https://www.hobart.com.mx/pdf/FichaTec/F-40196.pdf Service Manual https://hvac-talk.com/vbb/attachment.php?s=219f76d9e796c2e5f1c5fef6b79fad9d&attachmentid=830275&d=1639784925 from here https://hvac-talk.com/vbb/threads/2234701-Hobart-Service-Manuals ..
11/14/2023 10:10:01 PM • Hobart... • Answered on Nov 14, 2023
Hobart FT1000 Flight Type Commercial Dishwasher. The final rinse is not showing the temperature number.
Probably the temperature sensor, but do you want to risk $227 on a guess? It is a commercial machine, just call your local service tech. https://www.google.com/search?q=hobart+dishwasher+ft1000+service+manual+pd It is NOT a common fault https://www.google.com/search?q=hobart+dishwasher+ft1000+rinse+temperature+blank ..
8/17/2023 5:44:06 PM • Hobart... • Answered on Aug 17, 2023
2answers
Hobart AM-14 dishwasher is constantly filling with water.
Question edited for clarity and written English. It is a professional machine, you have it serviced professionally by your local Hobart Service Centre and claim the repair against your expenses. The machines are way beyond the capabilities of someone that can just buy parts online. It is either incorrectly wired or the control board or relays are are failing / failed.
8/16/2023 10:14:41 PM • Hobart... • Answered on Aug 16, 2023
2answers
What is wrong with Hobart dish machine says check water level
1.Loss of water pressure due to pump obstruction. Check for any obstruction at the pump intake. 2.Strainers clogged causing inadequate water supply to pump. 3.something may be inhibiting free movement of the low water float; remove any foreign object from around the low water float or its magnet.
4/13/2023 3:03:33 AM • Hobart... • Answered on Apr 13, 2023
Hobart AM14, the float assembly keeps failing. We are on our 4th one. Ruled out heat, electrical and we also replaced the main board. Anyone experienced this before?
It sounds like you're experiencing recurring issues with the float assembly on your Hobart AM14 dishwasher. You've already ruled out potential causes such as heat and electrical issues, and have even replaced the main board to try to resolve the problem. However, you're still encountering failures with the float assembly, which is unusual given that the dishwasher has been in use for 18 years without any prior issues with the float. Without additional information or an on-site inspection, it's difficult to pinpoint the exact cause of the float assembly failures. However, some potential causes could include:
  1. Damage or wear to the float assembly parts: Over time, the float assembly parts may become worn or damaged, which can affect their performance and lead to failures.
  2. Water quality issues: Poor water quality, including high mineral content or excessive amounts of chemicals, can damage the float assembly or cause it to malfunction.
  3. Improper installation: If the float assembly is not installed correctly, it may not function properly and could fail prematurely.
  4. Inconsistent usage: If the dishwasher is not used consistently or is used excessively, this could put strain on the float assembly and cause it to fail more frequently.
It's important to work with a qualified technician who has experience with Hobart AM14 dishwashers to diagnose and resolve the issue. They can inspect the dishwasher, including the float assembly and other components, and identify any potential causes of the failures. From there, they can recommend the appropriate course of action to resolve the problem and prevent future failures.
4/10/2023 7:40:21 PM • Hobart... • Answered on Apr 10, 2023
2answers
Hobart 130363 Commercial Dishwasher. Where is the fuse on the Hobert 130363 please
The cooling fan relay for the Alfa Romeo GTV6 1986 is located on the firewall, just behind the battery. The part number is 6043313.
3/2/2023 1:10:59 AM • Hobart... • Answered on Mar 02, 2023
Hobart SR24C-4 Dishwasher Logo
Popular Tags
22 questions posted
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
hobart dishwasher am14 rinse cycle
  • Dishwashers
