20 Most Recent
Pinnacle PCTV Pro PCI (230100070) Video Capture Questions & Answers
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
11/17/2017 3:44:33 AM •
Pinnacle...
Answered
on Nov 17, 2017
Record vcam now
No, well yes but you cannot access the neccasery data to take back what you have previously deleted..
2/9/2014 11:29:56 PM •
Pinnacle...
Answered
on Feb 09, 2014
I have purchased Dazzle V?D
if the device is showing the error "device not found" that means either the software of the device is not loaded properly on the pc.
or the usb wire is faulty.
or its not getting connected firmly at the position in the usb jack of the printer or the device..
check out this.
thanks.
10/30/2008 8:51:18 PM •
Pinnacle...
Answered
on Oct 30, 2008
Make movie disc ejects before
It sounds to me like the DVD ROM in your computer has the problem playing it's DVDs, so what happens when you play it in another Computer with it's DVD ROM?
8/10/2008 6:52:51 AM •
Pinnacle...
Answered
on Aug 10, 2008
Burning DVD
It can be downloaded from Pinnacle's web site (for a fee). I use version 11, and it appears to be fairly bug free.
7/1/2008 12:49:59 AM •
Pinnacle...
Answered
on Jul 01, 2008
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
