20 Most Recent Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Amana AFD2535FES... | Answered on Nov 08, 2012
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Amana AFD2535FES... | Answered on Oct 19, 2011
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Amana AFD2535FES... | Answered on Aug 24, 2011
The green residue you see is from the copper tubing corroding and since your unit is not cooling I suspect that there is a pinhole in the line that released the Freon. How old is this unit?
Amana AFD2535FES... | Answered on Aug 07, 2011
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana AFD2535FES... | Answered on Nov 17, 2010
Good day,
If both fans are running as well as the compressor, then it is one of these possibilities. Either the system has leaked all of the refrigerant out, or the system has an internal restriction, or lastly the compressor has failed internally with a bad valve ect.
All of the above items will require the attention of a qualified tech who has the proper tools and equipment to determine your problem.
Note: If the machine is under 5 years of age, then the factory warranty would be in effect. You would have to call the selling or servicing dealer to have it corrected, but it would be free.
Amana AFD2535FES... | Answered on Oct 16, 2010
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dyj56
Amana AFD2535FES... | Answered on Sep 30, 2010
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Amana AFD2535FES... | Answered on Aug 24, 2010
Good day,
What you have described sounds like a defective water valve on the back bottom rear of the machine. It will need to be replaced.
Although awkward, the best way is to remove the ice maker completely and let it air dry, while the valve gets changed.
The above diagnosis is based on the fact the freezer is maintaining it's normal temperature. If for some reason the freezer thaws and then refreezes that problem would need to be addressed first.
Amana AFD2535FES... | Answered on May 26, 2010
check cold control or defrost timer. then check compessor
Amana AFD2535FES... | Answered on Jan 02, 2010
if theres a circuit board look for a fuse that probably blew out.
Amana AFD2535FES... | Answered on Apr 23, 2008
Request from Amana or an appliance dealer.
Amana... | Answered on Jul 22, 2020
Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
29 questions posted
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
afd253dew stopped cooling
  • Refrigerators
