20 Most Recent U.S. Robotics USRobotics USR5451 Wireless MAXg Access Point wireless access point (S4199612) Questions & Answers
0answers
I can't ***** my USRobotics Router after i reset
The model number you provided is not a router, it is an access point. As such, it doesn't have its own native IP address, it gets one via DHCP when you connect it to your network. You should have received a setup disk with the access point that has a configuration utility. If you don't have the disk any more, you find the utility online at http://www.usr.com/support/product-template.asp?prod=5451. Use this to regain access. Otherwise, you can login to your current main ROUTER and check the DHCP table to see which IP addresses have been assigned. You should be able to tell which one was assigned to the access point. If you cannot figure out which one is which, just PING each one successively, and the results will give you NAME of the device you are pinging.
11/6/2013 3:19:28 PM • U.S. Robotics... • Answered on Nov 06, 2013
0answers
Reset robot
Be the first to answer 10/31/2013 5:48:52 AM • U.S. Robotics... • Posted on Oct 31, 2013Be the first to answer
0answers
I dont know wat is my username and password , then how can i change my network key
you might have to restore it to its facory settings
restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
You might need to do this if you are unable to access the Web User Interface or have forgotten your password.hope this helps
10/10/2012 12:45:35 AM • U.S. Robotics... • Answered on Oct 10, 2012
0answers
0answers
0answers
I have a part thats n1996. my pc is on xp but i
Looks like you may need some drivers! Go here to find them, all in one download for your convenience. Select the appropriate operating system, fill in the captcha, and select the US or EU server to download from. If you need further assistance, don't hesitate to send a reply.
9/21/2013 11:35:09 PM • U.S. Robotics... • Answered on Sep 21, 2013
Need software to install n1996 to my pc on xp
You need to install the drivers from this page. It's very simple, make sure you pick the according OS, which is Windows XP in your case. Then you need to enter the captcha code and select US or EU server to download from. If this is only partial to the software you need to use the N1996, feel free to respond for further assistance.
9/21/2013 11:32:03 PM • U.S. Robotics... • Answered on Sep 21, 2013
Driver for USRobotics
In what?
3/12/2013 7:33:29 PM • Computers &... • Answered on Mar 12, 2013
Lost cd
You can probably find the software on the manufactures web site and download it and run the software from the .exe file. Without knowing the model number of the Wireless Adapter I have no way of looking for you, but the manufacture should be able to provide it via download.
11/9/2008 9:12:27 PM • U.S. Robotics... • Answered on Nov 09, 2008
Recognition of US robotic modem
go to device manager and check if there are names under the modem and network adapter
10/10/2008 4:08:22 AM • U.S. Robotics... • Answered on Oct 10, 2008
Password problem
Look for the quick setup in the box, or try this http://www.usr.com/support/5461/5461-ui/setup_cable.htm
admin admin is what you're looking for.
Carl
8/27/2008 2:25:52 AM • U.S. Robotics... • Answered on Aug 27, 2008
Where can i get mastering machine learning Tips for Tackling Assignment
Mastering Machine Learning: Tips for Tackling Assignments Conquering machine learning assignments requires a blend of theoretical understanding, practical application, and strategic problem-solving. Here are some tips to help you excel:Foundational Knowledge: Solid Understanding of Concepts: Ensure you grasp the core concepts like supervised vs. unsupervised learning, different algorithms (regression, classification, clustering, etc.), and their applications. Mathematics and Statistics: Brush up on essential math and statistics, including linear algebra, calculus, probability, and statistical distributions. Programming Skills: Hone your programming skills in languages like Python or R, including libraries like NumPy, Pandas, Scikit-learn, and TensorFlow.Tackling Assignments: Thorough Understanding: Carefully read and understand the assignment instructions and objectives. Identify the specific problem you need to solve and the expected deliverables. Data Exploration and Preparation: Analyze the provided data: Understand the features, data types, missing values, and potential biases. Data Cleaning and Preprocessing: Address missing values, outliers, and inconsistencies. Feature Engineering: Create new features or transform existing ones to improve model performance. Model Selection and Training: Choose appropriate algorithms: Select algorithms based on the problem type (classification, regression, etc.) and data characteristics. Model Training: Train your model on the prepared data and tune hyperparameters to optimize performance. Evaluation: Evaluate your model's performance using metrics like accuracy, precision, recall, F1-score, or AUC-ROC curve. Experimentation and Iteration: Try different algorithms and hyperparameter settings: Compare the performance of various models to find the best fit. Cross-validation: Use techniques like k-fold cross-validation to assess modelgeneralizability and avoid overfitting. Regularization: Apply regularization techniques like L1/L2 to prevent overfitting and improve modelgeneralizability. Interpretation and Communication: Analyze results: Understand why your model performs well or poorly and identify areas for improvement. Visualize results: Use plots and graphs to illustrate your findings and insights. Clear Communication: Present your results and explain your approach in a clear and concise manner.Resources for Learning and Support: Online Courses: Platforms like Coursera, edX, Udemy, and Udacity offer comprehensive machine learning courses. Books and Tutorials: Numerous books and online tutorials cover machine learning concepts and techniques. Open-Source Libraries and Frameworks: Explore libraries like Scikit-learn, TensorFlow, PyTorch, and Keras for implementing machine learning models. Community Forums and Q&A Sites: Seek help and engage in discussions on platforms like Stack Overflow, Reddit's Machine Learning subreddit, and Kaggle forums. University Resources: If you're a student, leverage university resources like libraries, workshops, and professors' office hours. Remember: Practice is key: The more you practice, the better you'll understand the nuances of machine learning and improve your problem-solving skills. Start with simple projects and gradually increase complexity. Don't be afraid to experiment and try different approaches. Seek help when needed and learn from others' experiences.
4/24/2024 9:45:52 AM • Computers &... • Answered 4 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 9 hours ago
U.S. Robotics USRobotics USR5451 Wireless MAXg Access Point wireless access point (S4199612) Logo
7 questions posted
Top U.S. Robotics Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • U.S. Robotics Computers & Internet
Most Popular Question
dont know wat username password change
  • Computers & Internet
