20 Most Recent Bazooka MBTA8200 Marine BT Series 200-watt powered 8" bass tube Car Speaker Questions & Answers
Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
11/14/2007 6:08:11 PM • Bazooka MBTA8200... • Answered on Nov 14, 2007
0answers
Bt8250d is cutting out
Loose connection or your power cable and earth cable to your amp are not a heavy enough gauge.
11/30/2014 4:34:44 PM • Bazooka Car... • Answered on Nov 30, 2014
0answers
0answers
0answers
Speaker Fried, is my Amp toast too?
You are sending TOO much power to the speakers, Replace the speakers and then get a much smaller amp that is within the ratings of the speakers. ACTUALLY you should get an amp that is aboout 1/2 the total rating of the speakers.
You should ALSO procure a sound meter to verify the sound level is within safe limits. If you insist upon abusing your ears with too high a sound pressure, be ready to buy hearing aids at a VERY young age.
You also need to know that the enclosure of the speaker plays a part in keeping the speaker from tearing itself to pieces.
MANY of the auto sound system installers are hacks that don't do it right and you see what happens to your expensive equipment!
Using even a Radio Shack sound meter properly will protect your preciuos hearing for later life.
12/22/2009 9:19:21 PM • Bazooka Car... • Answered on Dec 22, 2009
Bazooka amp
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it remains in protect mode, the amp almost certainly has shorted output transistors and will need to be repaired.
6/15/2008 6:52:48 PM • Bazooka Car... • Answered on Jun 15, 2008
My GE Cafe cooktop CGP95362MS1 emits red flames on the Right Front Burner. I tried to clean it but to no avail. How can I correct that? Thank you
Remove the flame spreader and put it in a pan of cold water with a teaspoon of washing up liquid. Bring it slowly to a simmer. Be careful because it will want to boil over. Turn off the gas and leave it to cool. Use a plastic pot brush to clean and push the bristles down the holes in the flame spreader. Rinse and put it back, making sure it is seated properly. Most have a notch they must drop into.
3/27/2023 12:01:10 AM • Car Audio &... • Answered 2 hours ago
Wiring diagram for a Liebmaya remote to solenoid with top with four wires and a black green on the side.
Question edited to tidy up the written English. This looks link it might be a winch, but you posted to Car Audio! https://www.google.com/search?q=liebmaya+wireless+winch+remote+wiring+diagram ..
3/24/2023 1:29:46 AM • Car Audio &... • Answered 3 days ago
Hello! I need the code for the radio Grundig SC303 , sn: GM0303R1823989
dealer with vin and proof of ownership
3/23/2023 3:44:13 PM • Car Audio &... • Answered 3 days ago
2answers
2002 Citroen Saxo VTR with a locked radio - serial number is: CL040230893721D can anyone help me please with the unlock code? Many thanks
For Clarion radio codes contact this link with all the serial numbers from the radio and they will generate the code for you quickly and cheaply: https://www.vivastreet.co.uk/car-parts/hayes-ub4/car-audio-security-code/311088168
3/22/2023 1:48:09 PM • Car Audio &... • Answered on Mar 22, 2023
2answers
We have car audio that requires code, do you know the options how to unlock it?
If your car audio system requires a code to unlock it, there are a few options you can try: Check the user manual: The user manual for your car audio system may contain information on how to unlock it if a code is required. Look for a section on "security" or "anti-theft" features. Contact the manufacturer: If you don't have the user manual or can't find the information you need, you can try contacting the manufacturer of the car audio system. They may be able to provide you with the code or instructions on how to unlock it. Try common codes: Some car audio systems use a default code, such as 0000 or 1234. Try entering these codes to see if they work. Reset the system: If none of the above options work, you may need to reset the car audio system. This will erase any saved settings and data, including the code. The process for resetting the system will vary depending on the make and model of your car and audio system. Check the user manual or contact the manufacturer for instructions.
3/17/2023 10:03:22 AM • Car Audio &... • Answered on Mar 17, 2023
Working on a Rock-Ola 488 Jukebox. Looking for a block diagram of power distribution
Unfortunately, I do not have access to specific diagrams for the Rock-Ola 488 Jukebox. However, a typical power distribution block diagram would show the power source, such as the power supply, and the different branches of distribution to various components. These could include the amplifier, control circuits, motors, and lighting.
In your case, since you only have the power supply and power amp, you could start by tracing the power wires from the power supply and identifying which wires connect to the power amp. Then, you can look for any other components in the jukebox that require power and trace their wiring to the power distribution network. This should give you a general idea of how power is distributed throughout the jukebox.
3/17/2023 12:41:30 AM • Car Audio &... • Answered on Mar 17, 2023
Proton D940 stereo receiver. What kind of CD player and cables do I need to hook it up to the car?
The Proton D940 stereo receiver features both analog and digital inputs, so you have a few options when it comes to connecting a CD player to the receiver. For a digital connection, you will need a CD player with a digital output, such as a coaxial or optical output, and a digital cable to connect the two. Look for a CD player with a digital output labeled "coaxial" or "optical" and purchase a cable that matches the output on the CD player and the input on the receiver. For an analog connection, you will need a CD player with analog outputs, such as RCA outputs, and an RCA cable to connect the two. Look for a CD player with an analog output labeled "RCA" and purchase an RCA cable with the appropriate connectors to match the CD player and the receiver. Once you have the CD player and cables, connect the CD player to the Proton D940 stereo receiver using the appropriate input on the back of the receiver. If you are using a digital connection, select the appropriate digital input on the receiver using the input selector button on the front of the receiver. If you are using an analog connection, select the appropriate analog input using the same input selector button.
3/15/2023 4:29:43 AM • Car Audio &... • Answered on Mar 15, 2023
TOYOTA NHDN-W56 0845-00P51 | HDD Navigation. How to connect NHDN-W56 to battery please?
Question edited for clarity. Normally you need a harness if it is going in a different vehicle. Crutchfields sell them https://www.google.com/search?q=Toyota+nhdn-w56+wiring+diagram ..
3/14/2023 2:31:01 AM • Car Audio &... • Answered on Mar 14, 2023
What is the HLI port
What is the HLI port on the MTX tna251 amplifier?
3/12/2023 11:28:13 PM • Car Audio &... • Answered on Mar 12, 2023
2answers
Cq-vd6505u Car DVD
You can try to hold the right round selector knob to the right for 10 seconds while unit is on asking for code input. That will work to unlock if the previous owner did not set the 4 digit code. Good Luck
3/11/2023 10:56:58 PM • Car Audio &... • Answered on Mar 11, 2023
Bazooka MBTA8200 Marine BT Series 200-watt powered 8" bass tube Car Speaker Logo
1 questions posted
Top Bazooka Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bazooka Car Audio & Video
Most Popular Question
vrx bass tube built in amplifier
  • Car Audio & Video
