20 Most Recent D-Link DPH-50U (0790069289750) Router Questions & Answers
How to install d-link
See http://www.dlink.com/products/default.aspx?pid=DPH-50U&tab=3
for product documentation, including a quick install guide.
2/9/2010 1:16:07 PM • D-Link DPH-50U... • Answered on Feb 09, 2010
0answers
Using the D-Link skype/pstn switch with a SIP account
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
3/14/2009 3:33:44 PM • D-Link DPH-50U... • Answered on Mar 14, 2009
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
1/29/2009 6:42:25 PM • D-Link DPH-50U... • Answered on Jan 29, 2009
2answers
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
11/12/2022 5:02:31 AM • D-Link Computers... • Answered on Nov 12, 2022
My d-link dwm-156 3g after upgrading its firmware don't working!
I am sure it is now toast and you cannot downgrade if the wrong firmware has been installed. I would ask D-Link.
5/10/2022 11:44:35 AM • D-Link Computers... • Answered on May 10, 2022
2answers
I want to know how to setup the VPN on the D-Link 2750U modem
https://www.youtube.com/watch?v=zKeXtyUMKjA Check out this video it might help you with your issue.
12/22/2021 5:56:00 PM • D-Link Computers... • Answered on Dec 22, 2021
2answers
Multicast
Please open router page and go to advanced just like in this emulator. http://support.dlink.com/emulators/wbr2310/adv_network.htm
10/11/2021 6:58:31 AM • D-Link Computers... • Answered on Oct 11, 2021
I have a D-link dsl-2640u modem. Its Wi-Fi drops randomly and it cannot be found on any device (several phones and laptops). After some minutes it appears again! Factory reset didn't work.
try changing the channel number from auto to a channel number 2 or 3 higher than the lowest channel number.' do this by logging into the d-link dsl 2640
3/22/2021 11:55:25 AM • D-Link Computers... • Answered on Mar 22, 2021
Access violation at address 006A87BA in module
access violation in module Uimain.exe at address oo6F6AB6 read address 000002EC
2/13/2020 3:44:36 PM • Computers &... • Answered on Feb 13, 2020
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG ) page 7 is setup. NO OS stated by you, at all. why:? page 3 is OS compat. after reset the default address is 192.168.0.10 5volt power pack is NOT OPTIONAL. 1998 what did you read the free manual yet. the last page shows printer compatibility list, does your match? where would you find a printer that old working now. crickets...??? my guess is 2003 year made. XP first release is that. one manual for it stamped 2003 so is 17 years old relic fodder for sure, recycle it is best. first hit https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf RTM ! no 17 year old printer works today, not really.
12/19/2019 2:34:13 PM • D-Link Computers... • Answered on Dec 19, 2019
How to change password D-Link router DIR-655
the manual is free , at dlink dot com you push the reset button for long time per manual 15sec (iirc) the release it and now all defaults are set. per the manual, google dir-655 manual. easy as pie if you just read the manual.
12/12/2019 11:01:39 PM • D-Link Computers... • Answered on Dec 12, 2019
2answers
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
12/4/2019 9:35:57 AM • D-Link Computers... • Answered on Dec 04, 2019
D-lInK rOuTeR sUpPoRt pHoNe nUmBeR~+1:[877]:[769]:[O969].hElP
You can get best d-link router support phone number at Toll Free Number ( 1-877-769-0969 ). D-link router Tech Support number ( 1-877-769-0969 )
11/12/2019 5:58:02 AM • D-Link Computers... • Answered on Nov 12, 2019
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/11/2019 6:44:59 AM • D-Link Computers... • Answered on Nov 11, 2019
D-liNk rOuTeR sUpPoRt pHoNe nUmBeR $1.{877}*{76.9}*{09.69}*#$ 24/7
KATHERINE, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/26/2019 2:45:15 PM • D-Link Computers... • Answered on Oct 26, 2019
D-Link RoUtEr pHoNe nUmBeR $1.{877}.{76.9}.{09.69}.HeLp 24/7
SUSAN, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
10/19/2019 5:06:26 PM • D-Link Computers... • Answered on Oct 19, 2019
Help finding out my lost Network Key for an SMC Network router
go to dos prompt in a windows pc and type in ipconfig and press the enter key to find the default gateway address it might be 10.0.0.1 or 192.168.0.1 these are the most common. Type the ip address into internet browser to log into the gateway router. There will be an admin user name and admin password. It might be the default or it might be written hopefully on the router case/ try Username: cusadmin Password: password IP Address: 192.168.0.1 http://www.cleancss.com/router-default/SMC/SMC8014WG if you get into it look up wi fi security to find out the wep key or wpa key
8/23/2019 1:12:42 PM • D-Link Computers... • Answered on Aug 23, 2019
How to Contact D-link Support Australia?
At D-link, we understand the necessity of 24/7 need for an internet connection to connect you with the outside world along with providing you with optimum results as well. So, if you are facing any technical issues in your router and unable to solve it by yourself then with the tech support you can ask our experts. We will provide you Toll-Free Dlink Support Number Australia +1 888 597 3962 and online live chat so that you can reach us any moment according to your convenience. The well-experienced and highly motivated technical teams with their years of experience at D'link Tech Support will patiently listen to your issue and provide you with an efficient solution. You can contact our specialists at the provided number and our customer care unit will give you the necessary assistance to resolve your issue. Our customer care number is always there to take care of all your Internet-related issues and will provide you with the best available solution to permanently resolve the issue. We provide a friendly environment and take care of each complaint and feedback to provide better services to our clients. The Toll-free Dlink Helpline Number Australia +1 888 597 3962 and help centers are available 24/7 to assist our customers and free you from your distress of the web connection of the modem and the router. At Dlink, each customer is like a member of our big family and we love to get feedback from them. So, whatever be the need we are there to serve you the best we can. For any kind of technical help during the process contact, Router Technical Support team to get an instant solution. They are available 24/7. Call Now ?+1 888 597 3962 for any Support. More Info - https://www.quickhelps.co/phone-number/d-link/
7/22/2019 5:15:52 AM • D-Link Computers... • Answered on Jul 22, 2019
D-Link DPH-50U (0790069289750) Router Logo
7 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
using d link dph 50u softphone ie
  • Computers & Internet
