20 Most Recent Dual XDM6830 CD Player Questions & Answers
this sounds like a wire has cum loose or ur cd player sensor has been damaged
Dual XDM6830 CD... | Answered on Mar 20, 2008
Hi Ant81,
You should only have the Blue wire from the Dual connected the REmote terminal on the Jensen Amp. The Audio cables are the only other wires that connect from the Dual to the Jensen Amp.
Dual XDM6830 CD... | Answered on Nov 26, 2007
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Dual XDM6830 CD... | Answered on Oct 26, 2007
I have a 2004 dodge ram and once I hook up yellow wire it blows a fuse any help would be nice
Dual Car Audio &... | Answered on Nov 15, 2019
I wouldn't, you need an amp that can support a 1.1 ohm load. I don't know of any head unit onboard amp that can!
Dual Car Audio &... | Answered on Oct 20, 2019
Hi Chris, from what you said, it would seem like a loose antenna connection problem
Review and comment
Greetings Franco Dosil
Hola Chris, por lo que comentas, parecer?a un problema de conexi?n de antena flojo
Revisa y comenta
Saludos Franco Dosil
http://www.ps2netdrivers.net/manual/dual.xdm6820/
Dual Car Audio &... | Answered on Oct 12, 2019
Hi Robert, whenever you put two or more speakers in parallel, the power handling must be equal in each speaker and the sum total of the power of the speakers, must be greater than the power of the amplifier, to avoid breakages due to excesses of power
I hope my comment has served you
Hola Robert, siempre que pongas dos o mas parlantes en paralelo, el manejo de potencia debe ser igual en cada parlante y la suma total de la potencia de los parlante, tiene que ser mayor a la potencia del amplificador, para evitar roturas por excesos de potencia
Espero te haya servido mi comentario
https://www.bossaudio.com/manual/BE4000D_EN_UM.PDF
Dual Car Audio &... | Answered on May 29, 2019
Check all wiring/connections, fuses, etc. and don't forget the one on the back of the deck itself!
Dual Car Audio &... | Answered on Mar 19, 2019
YOU MIGHT TURN YOUR HEAD LIGHTS OFF
Dual Car Audio &... | Answered on Mar 10, 2019
Dual XDM6830 CD Player Logo
4 questions posted
Top Dual Car Audio & Video Experts
Ekse
Marvin
Marvin
Larry Tezekjian
Larry Tezekjian
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Car Audio & Video
Most Popular Question
cd player not working reads error02
  • Car Audio & Video
