Hi.
Since the problem is intermittent, start checking from the lamp cage door lock. A defective lamp cage lock can result in similar problems.
The same problem is commonly given by a defective lamp. There is no way of testing a DLP lamp, then the lamp gets usually replaced before repairing the rest. If the lamp has many hours of use, replace the lamp first, then work on the rest.
If the lamp is OK, then it is either a bad PSU or a defective ballast. The PSU supplies power in different voltages. Each line is independently used for a different function. If the PSU is defective there can be intermittent power to the lamp while the rest of the TV functions are working. Power to the lamp goes through the ballast. The ballast is the board that supplies power to the lamp. With both PSU and Ballast problem you may have video going off, or TV going to forced standby with LED blinking with no additional problem (no sound or picture issues before going off).
Ballast and PSU are tested reading voltages. If both parts test OK, then the problem is the digital controller board. In that case the protection circuit it is likely faulty.
Here a service manual for this model at $7.99:
M50WH185 ...
