20 Most Recent Samsung SF-565 Laser Fax Questions & Answers
I've never had it be a switch, so that leaves you with a power supply issue :-(
Since u checked the fuse it means that everything else is fine u just need a new power supply :-)
Samsung SF-565... | Answered on Feb 21, 2011
As soon as you installed it, you prompted a change in the ink levels which will AUTOMATICALLY pop up on your screen when you are properly connected and attempt to print something. That is when you tell the system that it is a new cartridge. OR YOUR PRINT HEAD IS CLOGGED Brother printheads are very easily clogged with air bubbles so there is very high risk that refilling ink will damage your printhead. It is not worth it to save money on ink and wind up with danmaged or totaly nonfunctional printheads.
Samsung SF-565... | Answered on Jan 29, 2011
reinstall correctly the toner cartridge
Samsung SF-565... | Answered on Oct 11, 2010
1. can receive fax? 2.tel. line working fine?
Samsung SF-565... | Answered on Aug 15, 2010
most new machines will not work with refiled cartridge`s the samsung and the lexmark ar the two that play up the most, because refild cartrages now have an electronic chip in them , the cartrage is telling the machine that it is empty and thus the machine is not accepting the cartrage
Samsung SF-565... | Answered on Apr 13, 2010
My guess is that this cartridge is remanufactured??
It requires a chip or fuse be replaced, in order to reset the machine when you replace it, and maybe this chip is defective or was overlooked.
If it's an original Samsung, then this is not likely the problem.
Samsung SF-565... | Answered on Mar 12, 2009
Go to service mode and rest counter
Samsung Office... | Answered on Sep 14, 2020
Try factory rest your printer and try printing again
Try cleaning the transfer belt and the four drums. Use a soft cloth to wipe the drum
try going to service mode on the printer, go to service function & select parts replacement alert and disable the notification on OPC so that it doesn't show toner reading.
try going to service mode and turn off the notification for the toner
The latest driver for your scanner needs to be installed on your PC.
In order for the print out to be clear, the paper path, drum and the transfer belt should be clean & the waste toner container should be empty. If doesn't work replace the drum.
Test the power cable on another printer and sees if it powers it..check the power supply if it is up to or not more than the required output voltage to power the printer..if problem persist check power board of the printer and read if their is still continuity on the fuse ..read the fuse with multimeter..the fuse if the printerust have been discontinued
Samsung Office... | Answered on Sep 09, 2020
Samsung SF-565 Laser Fax Logo
16 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
changing cartridge
  • Office Equipment & Supplies
