20 Most Recent
Bunn BTX 10-Cup Coffee Maker Questions & Answers
Bunn BTXB is leaking when
Bunn sells a de-liming kit that should take care of your corrosion problem. Most water supplies have some impurities and tend to "lime up" over time. Flushing the coffee machine every month or so with a vinegar/water solution will usually take care of the problem but if you've got visible signs of lime build up, you should do a thorough cleaning. The link to the Bunn Deliming + Sprayhead kit is below:
Bunn Home Deliming Spring and Sprayhead KitBest of luck!
Greg
Bunn BTX 10-Cup...
Answered
on Nov 20, 2009
My commercial bunn coffee maker is only brewing a half a pot even though I'm pouring in a full pot of coffee water??
Im assuming you tried it more than once and the tank is full when you start? If your doing manual fill pour over the timer has nothing to do with that. If it's plumbed with a water line, before you start changing your timer for the brew cycle, first try the easy fix which is unscrew the spray head. it's the piece the water comes out to the basket. Take the cleaning spring tool and rotate it as you push it thru the tube you just unscrew the spray head from. As your pushing it thru it has two turns in it . Just rotate and push until you have gone thru the second one and then it's clear to the water tank. Unfortunately this doesn't always get it unplugged. Where the tube goes into the water tank there is silicone hub on the part that's in the tank and it can keep some of the lime buildup from being removed. You will have to take the top off and remove the tube to clean it if that happenes. Dont forget to unplug it first. The other common spot for a restriction is where the water leaves the pan your pouring into. You need to remove the pan to get the spray tube out anyway so look also at the big nut that holds the pan onto the tank.sometimes the hole will plug in the center .
Bunn Coffee...
Answered
on Nov 13, 2019
My Bunn coffee maker is making weak coffee
Couple of ideas.
Your weak coffee could be due to the machine not getting hot enough, which is usually caused by calcium scale buildup on the heating element (the "burner").
Try descaling with a citric-acid based cleaner, such as Dezcal or Durgol.
The second is the coffee your using is a weak blend. Try changing to a different coffee and see if the strength is better.
Bunn Coffee...
Answered
on Jul 15, 2019
