20 Most Recent Wagner Spray Tech 0515030 ProCoat 2800 PSI Airless Paint Sprayer with Swivel by Wagner Questions & Answers
nozzle head might be shut try turning it to open, you should here air coming out if air comes out but no paint comes out then paint is to thick and might need thinning, hope it helps.
Wagner Spray... | Answered on Jun 12, 2014
Atlas Copco has used John Deer Diesel engines in the past, that could be a warning or code concerning the engine since it starts with JD.
Air Tools &... | Answered on Nov 25, 2020
The Paslode gun can flash green and red due to several reasons; it includes:
  1. Either your co2 is empty, or your battery is dead.
  2. The pasload may have a bad cooling fan.
Air Tools &... | Answered on Nov 21, 2020
Request the manual from Boge.
Air Tools &... | Answered on Nov 20, 2020
take old o ring to any home depot or hardware store and get the same size
Air Tools &... | Answered on Nov 19, 2020
Request the manual from Mastercraft.
Air Tools &... | Answered on Nov 14, 2020
same thing happened to me take note that they used a manual trans bellhousing so you have to specify a manual trans starter different amount of teeth on flywheel
Air Tools &... | Answered on Oct 25, 2020
It is quite normal for the output line to exhaust into the atmosphere until the new pressure is achieved when reducing pressure. If it continues to leak the regulator is faulty.
Air Tools &... | Answered on Oct 24, 2020
If the air pressure in the tank doesn't reach the regular cut out pressure level and since then the air compressor is not able to turn off as the pressure never reaches the cut out pressure level, then look to the intake valve or and internal gasket leak as the possible source of the problem.
Air Tools &... | Answered on Oct 19, 2020
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
If you can't find a manual and the manufacturer or dealer can't help, you might find the information in an oil supplier's application catalogue.
Air Tools &... | Answered on Oct 17, 2020
The service light is not a warning. Warning will go out when problem is fixed. Service indicator is based on hours of operation. Codes are only available thru service techs or Atlas Copco if they will give it to you.
Air Tools &... | Answered on Oct 05, 2020
Wagner Spray Tech 0515030 ProCoat 2800 PSI Airless Paint Sprayer with Swivel by Wagner Logo
3 questions posted
Top Wagner Spray Tech Air Tools & Compressors Experts
Joe Garcia
Joe Garcia
Tom Chichester
Are you a Wagner Spray Tech Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Wagner Spray Tech Air Tools & Compressors
Most Popular Question
2 remove install brake booster master
  • Air Tools & Compressors
