20 Most Recent
Seville Classics MSC10166 Tower Fan Questions & Answers
I stupidly tried, in the
Unfortunately, no - the manufacturer does not supply replacement parts. It is a throw-away item.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Cleaning of the fans
When I called Seville Support I was told that you can NOT open fan to clean and may not get it together if attempted (glad I stopped when I did!).
You need to use air pressure. After using much of a can of compressed air such as you would use on a keyboard and not getting too far, I broke out my seldom used air compressor which kicked out enough dust bunnies as to block out the sun. Hint: be sure to use outdoors. I'm happy to report both units working as good as new.
Don't have an air compressor? Ask your neighbor, he'll need the correct nozzle to 'blow air' (it comes in handy for many tasks).
The fan has power and will rotate, but no air is
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
