20 Most Recent Kaz Honeywell QuietClean HFD-135 Air Purifier Questions & Answers
The back part that goes on next to the cord has to be in place and secure other wise no function will come on.
Kaz Honeywell ... | Answered on Jan 28, 2013
i need infomation how to operate
Kaz Honeywell ... | Answered on Jan 29, 2009
Manual can be found here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=47a366c04a65e77c69850893b979e142
Kaz Honeywell ... | Answered on Dec 08, 2008
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
Kaz Honeywell ... | Answered on Apr 02, 2008
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Kaz Honeywell ... | Answered on Jan 12, 2008
Check to see if there is power getting to your device. If it is a 110-volt unit, plug a lamp or other device into the same outlet the device is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet. If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas: Wiring (Inspect for any broken or burnt wiring) Selector switch Control board Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
Kaz Air... | Answered on Oct 10, 2010
HOME IMPROVEMENT STORE PROBABLY IN ELECTRICAL DEPT
Air Purifiers | Answered on May 13, 2020
Pull off the front panel and look at the upper right, you will see two holes. One on top is the size of a pencil, and one below it the size of a dime. Use a paperclip, pen tip, ect and push the reset button in the center of the dime sized hole.
Air Purifiers | Answered on Mar 18, 2020
You would have to pull the ballast transformer out.
Pull the light fitting out.
Fit a new socket.
Run the mains wires that went the ballast transformer to the new socket.
Air Purifiers | Answered on Jan 10, 2020
Support at Guardian
https://www.guardiantechnologies.com/support
From your previous question: the Replace HEPA filter light wont go off.
Note: When you add information to a question, please use the Comment or Edit feature to add it to the same question, rather than opening a new question, because the new one has no link to the older one.
Air Purifiers | Answered on Nov 04, 2019
Kaz Honeywell  QuietClean  HFD-135 Air Purifier Logo
Popular Tags
14 questions posted
Top Kaz Air Purifiers Experts
Marvin
Marvin
john h
Are you a Kaz Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Kaz Air Purifiers
  • Kaz Air Purifiers
Most Popular Question
honeywell hfd 135 lost instructions
  • Air Purifiers
