20 Most Recent Amana PTH153B50AJ Heat Pump Air Conditioner Questions & Answers
im guessing its there way of defrosting the coils , as with this type (small) its tough to defrost the coils in an efficient way , hp runs normal to within one or two degrees of setpoint , hp shuts off or reverses in low speed , back up heat comes on to complete the room heat and to generate the heat needed to defrost the coils , entire unit shuts off when set point is reached , reversing valves set for heat and wait till next cycle
now mine does something slightly different : it runs for fifteen minutes and if set point is not reached it switches to back up and reverses the coils ,leaves compressor on (low speed) , this heats the coils up and defrosts the outdoor unit , and if it runs long enough twenty minutes total time , it goes back to normal and aux heat shuts off . this drives me insane thinking how much im spending on heating the outside !! but im sure its needed to prevent ice build up on outdoor coils ,and I sure don't want that cracking with ice formations
Amana... | Answered on Jan 30, 2016
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Amana... | Answered on Oct 27, 2015
if some units detect ice they will leave the fan running in an attempt to defrost the coils. If it's the outside coils and it's warm enough inside, try running the air conditioning for a few minutes, that will put hot coolant through the coils and could melt the ice for you.
Amana... | Answered on Apr 07, 2015
Change motor to check do a amp draw find out how many amps motor is drawing this may tell you that motor is going
Amana... | Answered on Oct 25, 2013
This sounds like a freon problem your system probably has a leak in the system somewhere. Amana has tons of problems with there equipment. They make there coils paper thin and they split especially on a heatpump. Amana used to be a good brand and then got bought out by goodman manufacturing and have turned there product into ****. How old is this unit?
Amana... | Answered on Jun 14, 2011
Verify all your components are operating - Compressor? Condenser fan motor? Blower fan motor?
If not check voltage to any that are not operating.
If all components are operating and the coils are clean - the refrigerant level is most likely low.
Amana... | Answered on Oct 28, 2010
freon is low or outside is very cold
Amana... | Answered on Dec 04, 2009
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Amana... | Answered on Apr 14, 2009
I don't think it is possible but if it is.........follow this link for acquiring the manual for it. If you can't find the manual on-line, give them a call or email them and they will get back to you.
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=AMA
Amana... | Answered on Apr 06, 2009
Try the parts from partstore.com .
Regarding the manual you can get from ebay or ciao.
Amana... | Answered on Nov 23, 2008
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Amana... | Answered on Mar 16, 2008
Find the drain outside and attach it to a wet vac, or blow into it. The drain will be in the bottom tray.
Page 35 and 36 of the service manual
https://hvacdirect.com/hvac/pdf/AMANA-PTAC-Service.pdf
Amana Heating &... | Answered on Jul 31, 2020
Goodman Industries has purchased Amana. So go to Goodman website for info. Without model number I cannot look up error code
Amana Heating &... | Answered on Feb 19, 2020
Amana PTH153B50AJ Heat Pump Air Conditioner Logo
24 questions posted
Top Amana Heating & Cooling Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
pthp shut off switch electric
  • Heating & Cooling
