20 Most Recent
RCA RTD209 System Questions & Answers
System will not come on
was the system on at the time if so you may have had a power surge which would have cook the system. sorry for the bad news. but it is an easy fix for a tech person take it in for repairs
When i turn system on
Something is overheating which is causing the unit to shut down to protect itself.
Try disconnecting the speakers and see if you get the same result.
If you do then the fault is with the Power Supply, if not then the fault is with the Amplifier.
RCA 5.1-Channel 250 Watt Home Theater System - Model RTD209
Unit was working fine,took a movie out,put in new one,but would not play.Tried hitting open button ,unit will not respond,all other functions working ok.
What could be the problem,is it worth fixing?/Is there a reset button somewhere on unit?
Help
Hey I bought the same exact thing open box missing same stuff. Manual is online at
http://www.thomsonnetwork.com/EN/Public
I have same problem with USB. Have you found out how to get a replacement for the MP3? or maybe model # for mp3?
Cd player
hey,
think you should return this set, they will give you a new one.
many cd players and dvd players are faulty today, or the laser just not precisely adjusted.
/michael
Repair and DIY blog
'why pay when you can play'
12/18/2007 12:29:14 PM •
RCA RTD209...
Answered
on Dec 18, 2007
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
