20 Most Recent RCA 27F634T TV Questions & Answers
It may be arching from the flyback. If you are familiar with tv's remove the plastic case plug it in and turn it on and see if you can see anything visual happening. Make sure not to touch anything and keep a safe distance when inspecting.
RCA 27F634T TV | Answered on Oct 30, 2012
SDA [Serial Data] bus is busy or interrupted. Seek tech support. This is a very skilled work, need all measuring instruments, and through knowledge in electronics.
RCA 27F634T TV | Answered on Jun 11, 2012
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can gather all details. Sometimes, click open the adverts' by the side and bottom of each post might give you more details.
RCA 27F634T TV | Answered on May 28, 2012
cambiale el flyback y ponle la memoria original de vuelta. cuando encienda trata de ajustar el control de screen en el flyback hasta el punto en que cuando cambies los canales no se apague. creeme que esto me tomo mucho tiempo en encontrarlo pero al fin lo arregle. The Tech
RCA 27F634T TV | Answered on Oct 28, 2011
Hello
If the tv clicks SEVERAL times like it is trying to start but just cant make it over the hump this is "GENERALLY" a power supply problem. Bad Caps tend to make this happen and are fairly easy
to change by someone with a little know how. However, the bad caps could be hiding a larger
issue that only someone who is skilled can really troubleshoot.
If your tv is suffering from a powersupply many times they can be purchased on ebay, or sometimes you can find them totally rebuilt.
I hope this helps
RCA 27F634T TV | Answered on Nov 24, 2010
u are getting problems with horizontal driver trans former
u have to replace it. some time it works normally when
copper wire windings get connected.
RCA 27F634T TV | Answered on Mar 12, 2010
on that one ive had the button board causing problem--remove board--spray wd40 on buttons--push buttons a few times--wipe off bwd--reinstall bwd
RCA 27F634T TV | Answered on Sep 16, 2009
you may need the digital converter from radio shack or best buy
RCA 27F634T TV | Answered on Jun 29, 2009
You will need to replace the transformer on the power sector. it has failed.
RCA 27F634T TV | Answered on Jun 05, 2009
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
RCA 27F634T TV | Answered on Mar 11, 2009
Hi..i have the exact same problem. Did you find a solution for this? Please let me know.
Thanks,
Srikanth
RCA 27F634T TV | Answered on Jan 05, 2009
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. [email protected] I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
RCA 27F634T TV | Answered on Nov 01, 2008
Ts it in video mode?
RCA 27F634T TV | Answered on Aug 16, 2008
i need the make and model of your television.. usually the red light blinks out a code. i need to know how many times it blinks as well. so i can find out what code it is producing.
RCA 27F634T TV | Answered on Aug 10, 2008
You would be astounded at how expensive a replacement panel for a television is. Even if you could find one, it would probably be cheaper to just replace the television. It seems like they do not want to repair anything anymore. I had a screen go bad on a 42 inch tv, and it was cheaper to just buy a new tv than to replace the panel.
RCA Televison &... | Answered Yesterday
RCA 27F634T TV Logo
Popular Tags
16 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
necesito data eeprom de tv rca 27f634t
  • Televison & Video
