20 Most Recent World Office Products Papermate PM-1550CD Shredder Questions & Answers
Hi, this is usually caused by either a jammed up motor, blown motor or a faulty power supply, either external or internal or both. If one is handy, these may be disassembled and the problem sorted out, either by un-jammimg the motor if jammed or replacement if burnt out, the PSU needs to be checked for volts out, If the Voltage of the external supply, if used, is OK, then suspect the internal PSU, the external unit can be replaced with any suitable same Voltage Current rating a power supply is a power supply as long as polarity is right you are all good.
However most often these types of units are beyond economic repair? Still there is never any harm if one doesn't wish to DIY to get a free "Quote" for repair from a suitable repair shop and go from there?
World Office... | Answered on Jun 18, 2011
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
World Office... | Answered on Jul 30, 2009
Your shredder is not dead It's just the (On and Off) switch not working properly (loose contact). Try to disassemble it and take a look if it's in the center location to make contact with On or Off positions.
But remember to clear the bin and remove any particles thats causing the clog or jam manually.
Thanks
World Office... | Answered on May 29, 2009
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
World Office... | Answered on Mar 27, 2009
Head PCB power supply error.
Abnormal power supply is detected on the Head PCB
Office Equipment... | Answered on Jul 29, 2020
Depends what it is on.
Office Equipment... | Answered on Jul 27, 2020
Perhaps the manufacturer/distributor.
Panasonic kx-ft981 ,dark print out and copy.
Office Equipment... | Answered on Jul 25, 2020
Canon Printer Error B200 means a faulty print head. A print head is a part that divides the ink from the cartridges on the paper, indicating it's one of the several important features of the entire printer. Print heads are known to be problematic, particularly on cheaper printers.
6 steps to Fix Canon Printer Error B200:-
1. Reset the printer.
2. Remove any obstructions.
3. Clean the printer head.
4. Manually clean the print head.
5. Remove old ink.
6. Re-install the printer drivers.
For Expert Advice check here- Canon Printer Error B200
Hello im using the ROHS mt871, and also have the Easy Cut Studio... Do i have to intall a driver first? or just by using "generic Plotter" i can cut? thank you so much
Office Equipment... | Answered on Jul 17, 2020
HOW WOULD ANYONE GUESS AT WHAT YOU HAVE
Office Equipment... | Answered on Jul 15, 2020
Are what ................ ?
Office Equipment... | Answered on Jul 11, 2020
Please error tds 450 10504-271
Office Equipment... | Answered on Jul 08, 2020
It'a problem with main motor encoder feedback. Usually problem with wires
Have you tried a Google search or Duckduckgo search for Dwf 7108? If so, you likely have discovered the device can not be found without other identifying information. If I assume it is a printer and not an office washing machine from DaeWoo, I find myself routed to AutoDesk forums. The point is, you need to identify the Brand and Model and type of hardware you are enquiring about, as well as error codes (which are typically specific to brand). Sorry. You might do a Google search for the brand named object and model number plus error codes or go to the manufacturer's site for support. I can't identify the hardware you are referring to.
Office Equipment... | Answered on Jul 07, 2020
World Office Products Papermate PM-1550CD Shredder Logo
Popular Tags
8 questions posted
Top World Office Products Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a World Office Products Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • World Office Products Office Equipment & Supplies
Most Popular Question
paper shreder light comes
  • Office Equipment & Supplies
