20 Most Recent
Panasonic Technics SL-BD22D Turntable Questions & Answers
What do i ground my turntable to ?
Any metal pipework such as a radiator. In some houses there are electrical earth points, like a metal tag. A green & yellow cable goes to them. It would be safe to use that, with a simple strand of wire, unsheathed wrapped around it, or attached by a crocodile clip.
Panasonic...
Answered
on Sep 01, 2015
My turn table is going
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Panasonic...
Answered
on Mar 24, 2011
Need a new AC power
Check with radioshack, they have many different options, they even have a universal adapter that can fit almost anything and and voltage needed.
Panasonic...
Answered
on Oct 29, 2010
THE BELT ON MY TURNTABLE SLIPPED OFF AND NOW I AM
Normally the belt does not go thoough any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes. Move by hand slowly to see waht happens. If the belt slips off again, it may be streched and needs to be replaced
Panasonic...
Answered
on Jun 08, 2010
Low volume after refitting belt on Technics SL-BS22B turnrable
check also the wire connections on the pickup head, don't forget to check the connections for the same wires inside the turntable, see if you have a bad solder contact to the output terminals, also check the terminals themselves for any dirt/oxydation (i assume they are RCA's, and they DO loose contact if you plug them in and out a lot). Also check RCA's at the amp end.
good luck
3rq8 (Triarcuate)
Panasonic...
Answered
on Jul 14, 2009
New cartridge for Technics SL -BD22D
the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
Panasonic...
Answered
on Feb 11, 2009
