20 Most Recent
Gli Pro SL-2100 Turntable Questions & Answers
Gli pro bd 1600 turntable
The GLI PRO BD1600 is a turntable, likely a budget model produced by GLI PRO, a brand that produces various audio and DJ equipment. Unfortunately, information on this specific model is scarce and I couldn't find much information on its specifications or features. It's possible that the model may have been discontinued or is only available in limited markets. If you're interested in purchasing a turntable, you may want to consider researching other models that better fit your needs and budget.
Blown fuses
Hi Anonymous. You have a few choices. You can download a PDF of the service manual ,or you can take the cover off and locate the fuse yourself. Chances are it may be more than one fuse blown. Some fuses are located under circuit boards..hard to get to. The service manual should tell you what kind of fuse you need. If you can`t replace the fuse yourself,you can always take it to an authorized service tech.
Need a new belt
Hi, we have belts for all models in stock. Cheers John. Stylus City
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
