20 Most Recent XRS-757 Radar Detector Questions & Answers
It could be picking up garage door openers, which are a common false alert for radar detectors. In a neighborhood, there are all sorts of sensors that give off false alarms. I usually turn mine off when driving through a neighborhood as police are less likely to be using radar (unless in a school zone).
XRS-757 Radar... • Answered on Apr 13, 2014
The Cobra XRS-757 is the same as the Cobra XRS-9330. The difference in model number is due to the 757 being sold at Wal-Mart stores.
XRS-757 Radar... • Answered on Aug 14, 2012
By Codes do you mean the X, K and Ka signals that the unit is reporting? If so, those are the 3 bands used for police radar. X is the oldest and not used very much. K is also an older band. Ka however is the newer band and the most used for speed tracking.
XRS-757 Radar... • Answered on Mar 21, 2011
The detector is not just for detector the presence of persons of law enforcement variety, but it is designed to detect a range of signals, and let you know.
K/Ka/Ku - Usually Speed Radar
X - automatic door openers (99%)
Lidar - "Laser Radar"
Strobe - Detects the flashing strobes on vehicles with flashing lights (police, ambulance, warning signs, school busses equipped with strobes, etc).
Other signals / situations as mentioned in the manual.
Note that if there is a cop nearby, the detector won't be able to detect the cop unless he pulls the trigger on his radar gun (aka instant on).
In case you missed it, here is the manual.
XRS-757 Radar... • Answered on Jun 28, 2010
X alerts are very likely false signals generated by automatic door openers, people / persons detectors.
K is a form of radar, be wary of these signals.
Here is the manual for your detector.
check wattage on unit and divide by voltage (12v) that = amps required in fuse and then add 2
example 120w % 12v = 10 amps
XRS-757 Radar... • Answered on Dec 29, 2009
Have you tried to plug something else in the 2007 to see if the power is present? May have a bad fuse.
Mike
XRS-757 Radar... • Answered on Aug 16, 2009
Do you want to replace it with the same thing or are you looking to add an exterior speaker to it? It's a very simple task to do, you need to disassemble the unit and find the piezo speaker that's currently installed to the board. The part number will be listed on it. It may even have a manufacturers name on it. Once you've got the info, you can go to the manufacturers website and get the specifications for it. If you want the same, any electrical parts site will sell it. If you want to increase the volume look for a piezo with a higher efficiency rating. There's only 2 or 4 solder connections that need to be made on the board to replace the piezo. If you want to get creative, move the speaker to the headliner on the drivers side and run a wire to the unit with a small quick disconnect so you can take out the main unit with ease. parts will cost under 10 bucks to do it. Hope this helps
XRS-757 Radar... • Answered on Jun 24, 2009
"K" IS LOCAL POLICE BAND, "KA" IS STATE TROOPER, AND "X" IS SILENT ELECTRONIC ALARM SYSTEMS. HAVEN'T FIGURED OUT WHAT "VA-2 ALERT" IS YET.
OTISRAYSR
XRS-757 Radar... • Answered on Jun 21, 2009
the fuse is located in the cigarette lighter plug, at the end you will see a silver cap and then the disk that goes over the top of it, that will turn and then you will have the front open to replace the glass fuse that is in it... to find the fuse size, after the fuse is out look at the silver ends it will have the size stamped on it... it might be a 40 amp fuse. or 20 amp. just look at the silver sides on the fuse you will find that there... hope this helps you out
XRS-757 Radar... • Answered on Jun 03, 2009
Try turning your inteli-mute off. If the inteli-mute (I-mute) is set with the RPM's too high it won't detect radar because the detector thinks you are traveling at a slow speed and detection is unnecessary. If your detector begins working, consult your owners manual to reset the I-mute limit if you want to use that option.
XRS-757 Radar... • Answered on May 04, 2009
do you have the manual? It sounds like, in your example, the unit is picking up X band at a signal strength of level 1.
XRS-757 Radar... • Answered on Mar 01, 2009
If you live near a cell-phone tower, your radar detector can pick up on the waves coming from it. If you like in an area where radar detectors are legal and Ku band is not used, I recommend turning off the vg2, spectre and Ku bands on your detector. This will not only cut down on some of the "noise" but also make your radar detector more reliable for when you are actually "zapped" by law enforcement.
XRS-757 Radar... • Answered on Dec 20, 2008
There are 2 options for power plugs that can be purchased from Cobra for the 757. The straight 12V power cord is listed under item number: 420-030-N-001 and the coiled 12V power cord is listed under item number: 420-026-N-001. Both can be purchased from Cobra by calling their order line at: 773-889-3087 or visiting www.cobra.com
XRS-757 Radar Detector Logo
42 questions posted
Top Cobra Vehicle Parts & Accessories Experts
Sheldon Dedek
Michael Thomas
Michael Thomas
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Vehicle Parts & Accessories
Most Popular Question
codes
  • Vehicle Parts & Accessories
