20 Most Recent
Kenwood KDC-MP2035 CD Player Questions & Answers
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
6/1/2018 12:42:55 PM •
Kenwood...
Answered
on Jun 01, 2018
Kenwood kdc-152 protext mode
Disconnect the power, check your speaker wire connections behind the stereo and at the speakers. Reconnect the power and test.
8/21/2012 2:03:49 AM •
Kenwood...
Answered
on Aug 21, 2012
I can not get the auxiliary to display on my deck,
In standby mode press Menu botton at least one second, "MENU" is displayed, with the control knob push towards FM or AM and look for "AUX OFF" item, then push toward > to select "AUX ON1", to exit press Menu botton. After this procedure the auxiliary input should be available as a sound source.
8/12/2012 7:08:13 AM •
Kenwood...
Answered
on Aug 12, 2012
Kenwood KDC-MP2035 cd player has power and
make sure that the power output is enabled. this will turn on you internal amp. I have the same unit and I fouund this to be a problem. If this does not work your out put amps might be fried. good luck.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
6/30/2012 5:26:10 PM •
Kenwood...
Answered
on Jun 30, 2012
Kenwood deck kdc-mp2035 im not sure about blue
Normally on Kenwood, blue is not usually used, it's for power antennae, make sure it's end is not bare though. Yellow would be to a continuous 12volt+, for memory. Red goes to accessory, (+12volt) where only power when key on, or in accessory position.
10/15/2011 3:07:06 PM •
Kenwood...
Answered
on Oct 15, 2011
I have a kenwood KDC-MP2035
try putting the radio in standby mode and then go into the menu. If you scroll through the menu you may have an option to turn aux on and off.
6/6/2011 6:14:49 PM •
Kenwood...
Answered
on Jun 06, 2011
