20 Most Recent Acer Aspire Timeline X 4830T 14 Inch Laptop - Aluminium Intel Core I3-2350M 2.3Ghz, Ram 3Gb, Hdd 500Gb, Dvd-Super Multi Dl, Lan, Wlan, Bt, Webcam, Windows 7 Home Premium 64-Bit Questions & Answers
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Acer Aspire... | Answered on Mar 19, 2017
Did you follow the initial charging instructions that came with the battery from the manufacturer? Does the battery fit properly and is not loose or gets loose during use/moving around? Are the cooling fans under the unit all clean, clear, unobstructed and working properly? Is the battery of the same type as the original? You can't always replace a Cadmium with NImh etc, the charger may not be compatible and give you erroneous indications and poor charging performance and may damage the battery.
Acer Aspire... | Answered on Feb 18, 2015
Are you using the provided charger, or are you using an after market "Universal" charger?
If you're using a universal charger, it could be charging the battery too hot and the computer just doesn't understand why the battery is putting out more than the system is expecting.
It could also be that the battery is wrong type. The voltage may be the correct, however the Ah may be too high. This being the case, the computer doesn't understand what why the it's getting a higher Ah reading than it's expecting. The system can not reason that that if it detects more amp-hours than the it should have that it has that much more charge time. It just sees "ERROR" and since you're dealing with a system function that is designed to prevent loss of data the default action is to shut down to prevent loss of data.
You may be able to fix by resetting the Power Management Options. Unfortunately, with out doing test on the machine, it is impossible to tell. I could be software or hardware. If nothing else works, try replacing the battery again.
Acer Aspire... | Answered on Oct 18, 2014
Mostly it should be RAM issue , Remove the RAM and clean it with eraser and refix it.
Acer Computers &... | Answered on Oct 22, 2020
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2057872.m570.l1313&_nkw=Acer+SP111-+31N+Power+Supply+&_sacat=0
Acer Computers &... | Answered on Oct 21, 2020
there is no driver required for ur monitor
Enter f2 to bios options
then go to boot order
Boot Priority Order:
PCI SCSI :
IDE CDROM : HL-DT-STCD-RW/DVD DRIVE-(P
PCI BEV : NVIDIA Boot Agent 244.0538
USB CDROM :
Excluded from boot order :
Item Specific Help
Keys used to view or configure devices : Up and Down arrows select a device. <+> and <-> moves the device up or down. <f> and <r> specifies the device fixed or removable.
<x> exclude or include the device to boot. <Shift +1> enables or disables a device. <1 - 4> Loads default boot sequence.
Select Item Select Menu
Change Values Select ? Sub-Menu
F9 Se F10 Sa
Setup Defaults Save and Exit
https://www.acer.com/ac/en/GB/content/drivers
Acer Computers &... | Answered on Oct 12, 2020
How to Reset your Acer laptop, when the Acer logo shows up on the Laptop computers screen press Alt + F10 to get into the recovery partition. If it is not able to restore to factory settings completely, you might need to restart Acer laptop, and press the F2 key to get into BIOS setting, and then go to Boot menu to set D2D Recovery as Enabled. 2.
Acer Computers &... | Answered on Sep 10, 2020
Insert the disc. Go to Computer >> Right click on DVD icon and click Auto play / Open with Windows media player. If the video does not play, you might have to download codecs from www.filehippo.com. Look for klite codec and install it. Alternatively you can use VLC player available at filehippo.com
Acer Computers &... | Answered on Aug 31, 2020
no model chromebook told. no model TV told
did you ask acer first. at omg, acer.com
here they are and do ask there, even to see if upgrades allow that.
warning they ask model numbers,
https://community.acer.com/en/
Acer Computers &... | Answered on Aug 30, 2020
You can use a DVD copy program like Nero if there is one on your computer.
Nero checks to make sure that you DVD isn't copy protected before it copies it. If it is you won't be able to copy it.
Windows XP or Vista does't provide DVD copy software built into Windows.
Acer Computers &... | Answered on Jun 30, 2020
*try it in other system
* change the cable of dvd
Hi! Try to download bluetooth driver for Windows computer with this tool! It is effective! http://www.drivethelife.com/free-drivers-download-utility.html
Acer Computers &... | Answered on May 26, 2020
Acer Aspire Timeline X 4830T 14 Inch Laptop - Aluminium Intel Core I3-2350M 2.3Ghz, Ram 3Gb, Hdd 500Gb, Dvd-Super Multi Dl, Lan, Wlan, Bt, Webcam, Windows 7 Home Premium 64-Bit Logo
3 questions posted
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
View Most Popular
  • Acer Computers & Internet
Most Popular Question
acer aspire 4830t battery behaving
  • Computers & Internet
