20 Most Recent Solid Audio F2500D 1-Channel Amplifier Car Audio Amplifier Questions & Answers
First disconnect the CD head unit from the sub amp and see if the other amp works. If yes, the problem is the wires to the amp, the amp itself, or the subs/sub wiring. If no, the problem is the head unit--probably an internal short.
If the other amp works with the sub amp disconnected, reconnect the sub amp to the head unit, but disconnect the sub wires from the amp. Try the CD player. If the amp goes to protect with no speaker wires attached, the amp is bad. If the amp is OK, the problem is the subs or sub wires. Hook the wires up to the amp again, but disconnect them from the speakers. Try the player again. If the amp goes to protect, the problem is the amp wiring. If not, the problem is the subs. Check the impedance of each sub using an ohmmeter to determine which amp is out of spec.
Please let me know if you have questions, and thanks for using Fixya.
Solid Audio... • Answered on Jun 11, 2011
Yes there is a remote wire that has to be switched on from the head unit. If you want the amp top be on all the time, simply connect up the remote power wire to the B+ wire, but I would not recomend that. Good Luck
Solid Audio... • Answered on Sep 07, 2007
No power should be applied.
Solid Audio Car... • Answered on Sep 24, 2018
From what I understand, the F15d is the same inside as the Sundown SAZ-1500d which is strappable (daisy-chain) via RCA's. So, I would venture a guess that it is in fact strappable.
Solid Audio Car... • Answered on Jan 11, 2011
You can go one of two ways. You can buy a high output alternator or run a extra dry cycle battery and you should run at least one or two capacitor here is a link for info: http://www.bestbuy.com/site/Rockford+Fosgate+-+1-Farad+Capacitor/8286482.p?id=1172880157454&skuId=8286482&st=capacitor
Solid Audio Car... • Answered on Jan 31, 2010
The reason why your faceplate keeps on falling out for your car stereo is because that part needs to be replaced.
Car Audio &... • Answered 2 days ago
You need to unhook the speakers and try the power again. When the protection light comes on it either means that the speakers have to low of a resistance or are shorted or there is another issue with the power, We need to be sure it is not the speakers. If the light goes out, power it off and hook up ONE and try again then keep going till you find the bad one. You did not say what amp it is so that is all we can provide
Possibly a supply voltage is missing. Maybe the power switch is faulty, usually a MosFet switch on newer models.
Car Audio &... • Answered on Apr 09, 2021
The Splunk Certifications provided by the team of Igmguru includes the complete aspects of Splunk developer along with the various administration and services. Eager to know, what is splunk? then don't wait and enroll for the Splunk Course provided by IgmGuru, then you should count on the words like Splunk installation and Configuration, Splunk Syslog, Syslog Server, log analysis, Splunk dashboard installation and configuration of Splunk. With all these things covered well in one's Splunk Certification Course, it is definitely an easy manner for the individual to make sure things are happening really well.
Car Audio &... • Answered on Apr 05, 2021
THE BRAIN FROM TOP TO BOTTOM
https://thebrain.mcgill.ca > i_11_cl_cyc > i_11_cl_cyc
THE NEURONAL SWITCHES FOR WAKING AND SLEEPING ... is lifted can the brain go through the alternating periods of non-REM sleep and REM sleep, ... Various groups of "REM-on" neurons have been identified for each of the intrinsic ...
https://thebrain.mcgill.ca > d_11_p_cyc > d_11_p_cyc
You spend the remaining two hours-roughly 20% of the night-in REM sleep. It seems that with training, people can gradually reduce their normal amount of sleep ... The problems of not providing make model (what it is) and using abbreviations. 'REM' is the abbreviation for 'Rapid Eye Movement' during sleep. Perhaps you mean ECM. 'Engine Control Module'? some do, some don't. Google year make model flash ECM
In a word no. It is not suitable for bridge mode as the output stage may destroy itself.
I want jvc kd-dv5606 front panel
Car Audio &... • Answered on Apr 02, 2021
Leave it switched on...undisturbed for as long as it takes to automatically reset itself (usually an hour or more)
Make sure you have the correct code
Car Audio &... • Answered on Apr 01, 2021
Car Audio & Video Logo
Popular Tags
6 questions posted
Top Solid Audio Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Solid Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Solid Audio Car Audio & Video
Most Popular Question
2 amps instalkled
  • Car Audio & Video
