20 Most Recent Canon imageRUNNER C5180 Color Copier Questions & Answers
Sometimes new OS versions are not backward compatible with older exterior hardware. Try going to Canon's website and finding an updated driver. Also try microsoft.com to get driver info for your printer.
Canon... | Answered on Jul 27, 2018
press star than #2 and #8 at the same time look for funtion and clear, press the error than clear power machine off than on see if that clears it
Canon... | Answered on Sep 29, 2017
Hi
what is the problem for E000110-0136
anton
Canon... | Answered on Mar 07, 2016
Hello Rama,
I will answer your question however you will determine the solution.This error code means that when your device went through it's "self diagnostics"in an effort to provide you with the optimum image quality a failure occurred.The target for image quality for BLACK could not be reached.The black drum has reached and went beyond it's ability function.Replace the black drum.The part number is 0258B001AA.It is easy to replace and there are many sources on the web.The cost is around 175 $US. . The estimated life of the black drum is 78K.Keep in mind that virtually every image you generate has a black component.The E000020 means one of your 4 drums have failed.The 0460 says 2 things.The 04 means black drum.The 60 that follows means which component of the black drum(the developer)has failed.I am glad to help you and save you a service call.Please let FIXYA know I helped you, and have a blessed life. SPINAL
Canon... | Answered on Jan 17, 2016
check the fans it is either spoilt or disconnect
Canon... | Answered on Aug 15, 2014
That error mean there is a sudden change in the fixing unit temperature.
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Canon... | Answered on May 30, 2014
Hopefully is just the hard drive failed, unplug it and retry. (turn off power first) -Carl
Canon... | Answered on Apr 21, 2014
Canon imageRUNNER C5180 Color Copier Logo
79 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
got error code e000007 0001
  • Office Equipment & Supplies
