20 Most Recent Connex 4400 320-Channels Base CB Radio Questions & Answers
NEED POWER CORD
should be the standard 3 pin plug for any radio .
9/3/2016 3:49:03 PM • Connex 4400... • Answered on Sep 03, 2016
Wanting info on my connex 4400 turbo how to peak and tune
unless you have the equipment to do this.. please take to a radio store. have them do it.. its free. or they shouldn't charge to do that service.. unless it needs a major factory alignment. also they shouldn't take out or clip anything in the process if they do find you another place LOL..
2/2/2016 4:12:18 PM • Connex 4400... • Answered on Feb 02, 2016
Can i get a connex turbo 4400 users manual
  • Yes you can. This is actually a service manual but it covers the basics found in the users manual in the first part of the first link. Also with a service manual you can dissect the radio to perform repairs.
  • Part 2 -
http://www.cbtricks.com/radios/connex/cx_4400_cx4400hp/graphics/connex_cx4400_cx4400hp_sm_pg16_pg33.pdf
Regards, Tony
4/30/2011 8:40:40 AM • Connex 4400... • Answered on Apr 30, 2011
0answers
I need to set my
Be the first to answer 11/28/2010 12:51:44 AM • Connex 4400... • Posted on Nov 28, 2010Be the first to answer
I need diagram connex cx 4400
1-SHIELD
2-AUDIO
3-TX
4-RX
YELLOW-N/C
MAYBE THIS WILL HELP
10/13/2009 4:52:09 AM • Connex 4400... • Answered on Oct 13, 2009
4answers
Connex 4300
Check for proper shielding,ground, turn mic gain down, move mike farther away from radio, turn off other accessories nearby-ie.-am/fm radio
3/24/2009 8:34:31 PM • Connex 4400... • Answered on Mar 24, 2009
2answers
Ranger 2980
it wasn't the 4558 chip... am still hunting...
6/6/2008 9:46:19 PM • Connex 4400... • Answered on Jun 06, 2008
Swr will not go under 2.5 even with antenna adjusted up and down
if your swr is higher on 1 then on 40 then your antenna is electrically short and you have to lenghten the antenna.If it is higher on 40 then on 1 then it is long and you have to shorten it. If you have to make it longer then you may have to add a quick disconnect or a coiled spring to make it longer. To make it shorter all you have to do is trim a 1/4 in at a time off the antenna whip but you must keep checking the match until it gets down below 1.5 .
10/3/2018 8:00:49 PM • Connex Radio... • Answered on Oct 03, 2018
My connex 3300hp radio randomly transmits and gets stuck without pressing mic button. It in sticks if you press mic button.
Have you tried keying it without the coax attached ? Take the mic apart and give it a squirt of electrical parts cleaner .Try using a different mic also.
10/3/2018 7:50:40 PM • Connex Radio... • Answered on Oct 03, 2018
Converting connex 4400 turbo to a cb
If you disable any part of the radio that does not pertain to CB then you could actually do damage to the radio. the best thing to do is leave it on the CB band and don't touch it.
10/3/2018 7:47:39 PM • Connex Radio... • Answered on Oct 03, 2018
When turn radio on channel indicator searches but will not stop search 3400 connex 3400
the radio is searching for a strong incoming signal and until it gets one it will search for one. Try turning off the scan button .
10/3/2018 7:44:35 PM • Connex Radio... • Answered on Oct 03, 2018
I stopped into a Radio shop and ask them for a power cord for my connex 4600 and he asked me what kind of truck I’m putting this radio in I told him a freightliner he said the connex 4600 Is the wrong radio for this this truck he said discharge don’t have a good ground I never heard that before
many trucks have a ground wire in the harness as the cabins are fibre glass or not grounded around the cabin mounts If the radio grounds out through the frame , then there would be no ground for the radio or the aerial wire to fit this particular may require such a wire in the harness for the radio which it probably doesn't have As you have been alerted to a problem, it would be advisable to talk with professional radio fitters who work on trucks to get the correct advice before starting on the job it could save a lot of frustration
11/23/2017 1:16:41 AM • Connex Radio... • Answered on Nov 23, 2017
Need a faceplate or faceplace sticker for a connex 4300x400wsm 10 meter cb radio. Any help at all would be greatly appreciated
Sorry we do not sell parts nor have the ability to locate them for you.
6/8/2017 6:29:00 PM • Connex Radio... • Answered on Jun 08, 2017
Connex 4400 320-Channels Base CB Radio Logo
Popular Tags
9 questions posted
Top Connex Radio Communications Experts
Tony Raia
Damon Nesselrodt
Damon Nesselrodt
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Connex Radio Communications
Most Popular Question
need power cord
  • Radio Communications
