Same thing happen to my blinder, it uses 5A fuse 250V. But even if you replaced the fuse it still blow up... some other issue related that make the fuse blow
Hello, Frances -
Your question landed in the Fixya.com category of Furniture. I re-categorized your question to the Oster Blenders category.
I found the following information regarding Oster blender built in fuses:
(Quote)
The built in fuse protection has kicked in. To turn the blender back on, first turn the control knob to "Off" and unplug the unit from the wall. Then remove the jar from the base and free the blade of any obstructions. Next, press the external resettable fuse button on the bottom of the base. Wait 30-45 minutes for the unit to cool.
(End quote)
Source:
https://www.oster.com/service-and-support/product-support/product-faqs/blenders/oster-versa/blenders-oster-versa-faq.html?faq=blenders-oster-versa-faq-Q-A-4
Question: My blender shut off during use. What happened?
If you try that possible solution and the blender still does not start, then . . .this is the link to the Oster Contact Us page:
https://www.oster.com/customerservicecontact?cid=contactus
At the very bottom of the page you will find toll free Customer Service phone numbers.
Or . . .
Fill in the form there, asking about the availability of a replacement fuse for your model of Oster blender, so that you can send an email message.
Best wishes.
there are compaies around that sell seals , bearings and "O" rings
see if you have such an operation in your state and contact them with the measurements of the seal
None of these people understand your question. The blade assembly is stuck in the blender base and will not untwist out of the base. The sport bottle untwists off the blade assembly leaving it in the blender base. I've tried using pliers on mine after taking it apart. Something is binding it from untwisting. What is the trick to untwist the blade assembly off the blender base?
