20 Most Recent Frigidaire PLEB30T9FC Electric Double Oven Questions & Answers
TURNED THE OVEN TO "CLEAN"
set the range as if you are setting it to clean and after you hear it cycle into clean then cancel and it should unlock ,,,, please remember to click on rating / thanks
11/30/2008 6:48:01 PM • Frigidaire... • Answered on Nov 30, 2008
2answers
Frigidaire Gallery Convection Oven CFEB786JGB3
Parts Schematic and wiring diagram. https://www.partselect.ca/Models/CGEB30S9FB3/ Part F161 is the Convection Element. Check it for continuity with a multimeter and also check the connection tags to it as they can melt. https://www.partselect.ca/PS2361497-Frigidaire-318255504-ELEMENT.htm?SourceCode=20&SearchTerm=CGEB30S9FB3&ModelNum=CGEB30S9FB3&ModelID=899380 ..
8/31/2023 11:47:04 PM • Frigidaire Ovens • Answered on Aug 31, 2023
Frigidaire Mdl: CFES387CFS6 oven controls do not work
If the display is blank then I would assume that the power board is dead and will need to be replaced
8/26/2023 6:41:46 PM • Frigidaire Ovens • Answered on Aug 26, 2023
Frigidaire Pro oven has error code F 14 and the temp probe has 1095 ohms. How do I troubleshoot the control panel?
F14 Misconnected keyboard cable Verify connection between display board and touch panel (2 ribbon cables). Make sure the cables are well connected at both ends. If the cables are good, replace the touch panel. If the problem persists, replace the display board.
8/1/2023 5:50:15 PM • Frigidaire Ovens • Answered on Aug 01, 2023
My frigidaire ovens broiler came on, on high, when i was baking at a very low temp (170).
If your Frigidaire oven's broiler unexpectedly turned on while you were baking at a low temperature, it could indicate an issue with the oven's temperature control system. Here are a few possible explanations and troubleshooting steps:
  1. Incorrect oven setting: Double-check that you have selected the correct oven function and temperature settings. Ensure that you have chosen the "bake" function rather than the "broil" function. Also, verify that the temperature setting is appropriate for baking.
  2. Malfunctioning temperature sensor: The oven's temperature sensor, also known as the oven thermostat, could be faulty. A malfunctioning sensor may send incorrect temperature readings to the oven control board, causing it to activate the broiler unexpectedly. Consider contacting a professional technician to inspect and potentially replace the temperature sensor if necessary.
  3. Control board issue: The oven control board, which regulates various oven functions, could be experiencing a malfunction. If the control board is sending incorrect signals to the broiler, it may activate when it shouldn't. Consult a professional technician to assess and repair the control board if needed.
  4. Wiring or electrical problem: Inspect the oven's wiring and electrical connections for any signs of damage or loose connections. Faulty wiring or poor electrical connections can cause erratic oven behavior. It's advisable to have a qualified technician examine the electrical components to ensure they are functioning correctly.
6/28/2023 4:10:16 AM • Frigidaire Ovens • Answered on Jun 28, 2023
Frigidaire Range FES367DBA
6/19/2023 4:24:18 PM • Frigidaire Ovens • Answered on Jun 19, 2023
Model #FEFL79DSA Frigidaire electric range. 2004 vintage. Last night wife was cooking supper at 350F. After half hour she noticed sizzling sound which was not normal.
Based on the information provided, it seems like there may have been a problem with the oven's thermostat or temperature sensor. It's possible that these components malfunctioned, causing the oven to continue heating beyond the set temperature. Since the issue seems to have resolved itself and the oven is currently functioning properly, it's difficult to determine the exact cause of the problem. However, if the issue occurs again, it's important to have a professional technician inspect and repair the oven to ensure that it operates safely and efficiently. Intermittent issues can be difficult to diagnose and can potentially be dangerous, so it's important to take any signs of malfunction seriously and address them promptly.
4/10/2023 7:42:43 PM • Frigidaire Ovens • Answered on Apr 10, 2023
2answers
How to remove a 1960s frigidaire compact 30 drop in oven?
unknown since fixya didnt install and dont know what installer did
4/2/2023 3:47:15 PM • Frigidaire Ovens • Answered on Apr 02, 2023
I have a Frigidaire oven that is giving a F3 code
Error Code: F3 Solution: The oven temperature sensor may be failing or defective. First, check sensor harness and harness connection between oven sensor and oven control to see if there is an issue with loose wires or visible damage to the wiring, such as a burnt wire.Sep 1, 2018
Frigidaire Error Codes Explained - D&T Appliance Service
3/8/2023 6:00:24 AM • Frigidaire Ovens • Answered on Mar 08, 2023
How do I jump test the limit switch on Frigidaire oven - FFEH3054USE?
Replace the switch...be sure to turn the Breaker to the unit off before servicing. https://www.repairclinic.com/ProductDetail/2453504?c=35 Their 800# people can assits you too, and videos on how it's done on the part discription.
2/23/2023 5:43:11 PM • Frigidaire Ovens • Answered on Feb 23, 2023
How do I take the door off the double oven Frigidaire professional series
Hello again :>D Videos
2/19/2023 12:15:59 AM • Frigidaire Ovens • Answered on Feb 19, 2023
Where can I get my Frigidaire double oven door glass repaired
You can buy the new glass yourself and do it, as an easy task. Or you just called a Figidaire service tech. You will need the model number and you don't tell us :>D https://www.google.com/search?q=frigidaire+gallery+oven+door+glass+replacement videos for inner and outer door glass
2/18/2023 11:40:18 PM • Frigidaire Ovens • Answered on Feb 18, 2023
I have a Frigidaire oven that's does not heat up to high temp.
If your Frigidaire oven is not heating up to the high temperature, there could be a few possible causes:
  1. The thermostat may be malfunctioning: The thermostat controls the temperature of the oven and if it's not working correctly, it could prevent the oven from reaching the high temperature.
  2. The heating element may be malfunctioning: If the heating element is not working properly, the oven may not be able to reach the high temperature.
  3. The control board may be malfunctioning: If the control board is not functioning properly, it may not be sending the correct signals to the heating element or thermostat, preventing the oven from reaching the high temperature.
  4. The oven may be in a cleaning or self-cleaning cycle: when the oven is in a cleaning cycle, the temperature is raised to a high level to clean the interior of the oven.
  5. The oven may be in a energy saver mode: some ovens have a energy saver mode that decrease the temperature by a certain degree to save energy.
1/24/2023 8:03:58 AM • Frigidaire Ovens • Answered on Jan 24, 2023
3answers
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,unsafe to use at any time if the temp controller trips the circuit breaker could be the oven thermostat causing the trip as well if Frigidaire are still in businessYou will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
1/16/2023 8:12:56 AM • Frigidaire Ovens • Answered on Jan 16, 2023
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature. https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea... A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ... ‎How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Why You should Never Run A Self Clean Oven Cycle & A ...
https://www.generalappliancesvc.com > why-you-shoul... Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
11/17/2022 5:17:07 AM • Frigidaire Ovens • Answered on Nov 17, 2022
While baking in frigidaire wall oven the broiler will sometimes turn on and code f3 pops up model FEB786CEBH.
10/10/2022 3:24:42 PM • Frigidaire Ovens • Answered on Oct 10, 2022
2answers
Frigidaire GLEF378ASE range oven cuts off during self cleaning mode.
My advice is never to use the self cleaning feature. Each time you use it you are a little closer to breaking something, elements, fans, door latches and one poor man who had a burned / melted control board which was obsolete so he had to purchase a new range. We see it here all the time. It is a great way to sell spare parts. 800 to 1000'F is just too severe for the parts.
https://www.generalappliancesvc.com > why-you-shoul... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 ...
8/28/2022 9:28:29 AM • Frigidaire Ovens • Answered on Aug 28, 2022
I need the Broiler element for the top oven of the frigidaire RBE-97N In wall oven
order one fixya doesnt sell products
8/17/2022 2:01:53 PM • Frigidaire Ovens • Answered on Aug 17, 2022
2answers
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
Exact same thing happened to me. After a power failure my Frigidaire stove worked and the clock worked but bake broil and self clean gave me a DR error. Tried everything to reset nothing worked. When I unplugged and plugged back in I got an f13 code.I changed the control board and the entire oven is back in business!c86f7aab-24e4-4403-bcd6-0b838d53ac57.jpeg
7/2/2022 12:54:14 AM • Frigidaire Ovens • Answered on Jul 02, 2022
Frigidaire PLEB30T9FC Electric Double Oven Logo
Popular Tags
1 questions posted
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
turned oven clean
  • Ovens
