20 Most Recent
Sharp R-520LK Microwave Oven Questions & Answers
I have an awesome sharp carousel sensor microwave
Get some paper towels and clean the insides out with vinegar, do this once every two hours over a period of 8 hours. Then leave a box a baking soda inside the microwave with the door open outside overnight.
That should do the trick!
I'm getting an arc after
Quite
often this is due to grease or food particles stuck somewhere in the
cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the
area of the turntable support, coupler, or motor.
The
waveguide cover (also called a spatter shield) is usually about the
size of a playing card and often held in place by a plastic rivet.
It can be fragile, and
the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal
behind it should be cleaned with a mild, non-ammonia cleaner.
The area will
first have to be sanded smooth and
cleaned and dried thoroughly.
If the cavity metal of
the oven is cracked or split, you can use a small amount
of steel-based epoxy such as JB-WELD
to patch the crack or hole.
Once that dries
thoroughly, you can sand it very smooth.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
If your
waveguide cover
is burned, it will need to be replaced.
It provides critical
protection for the magnetron.
We have the service manual for this model and have uploaded it for you here.
You can order
Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Model 520lk.can set time colck
The microwave oven has got a couple of safety components to protect it and the people from harm. One is an interlock switch to prevent it starting if door is not properly closed. The other is a thermal fuse which blows if the oven becomes too hot.
In your case it is likely the thermal fuse is blown. This prevents the oven turntable, fan and the magnetron (the main microwave generator) from starting.
You can find the details in the service manual
http://207.234.249.73/mwd/r520lk_r520lw_sm.pdf
But I would not recommend you to fix it yourself if you are not familiar with electrical gadgets, especially the micorwave because it is unsafe and has very high voltage.
Please post a comment to confirm you have understood my solution to your problem.
My microwake is not working
microwaves are cheep, unless you have repair skill`s in this field your best to have it serviced or get a new one
Light comes on and time counts down, but fan
You didn't mention your brand or model number, but since you posted this under Sharp, maybe it's a Sharp?
If so, in most cases, this will usually be a bad bottom door switch or door switch mount.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
You can find links to helpful exploded view
diagrams and part ordering help
here.
I recommend that you bookmark that
link to your favorites.We're
Sharp R-520LK is arcing.
Quite
The metal
If the metal is chipped or charred, the area will first have to be sanded smooth and
If your waveguide cover
is burned or damaged, it will need to be replaced. It provides important
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.We're
