20 Most Recent Logitech FreePulse Wireless Consumer Headphones Questions & Answers
I had the same issue. I called logitech and they replaced the entire kit with the latest model with Bluetooth, So i sorta of got a free upgrade.
Logitech... | Answered on Jan 12, 2017
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Logitech... | Answered on Dec 20, 2016
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Logitech... | Answered on Aug 22, 2014
There will be a hole at the top my iPhone has one
Logitech... | Answered on Sep 21, 2013
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Logitech... | Answered on Apr 09, 2013
You can buy here: http://buy.logitech.com/store/logib2c/en_US/DisplayCategoryProductListPage/[email protected]&rests=1357202423124
Tim
Logitech... | Answered on Jan 03, 2013
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Logitech... | Answered on Nov 13, 2010
Have you tried doing the same with the headphones? If you hold the power button down on both the transmitter and heaphones (get them both flashing red and blue), they might pair.
Logitech... | Answered on Sep 11, 2010
Reinsert batteries in your head phone that can be dislocated due to drop.
Thanks.
Logitech... | Answered on Jun 10, 2010
Thank you SO much , i know this is old, but i recently had mine repaired and i thought i'd have to do it again but you saved me a weeks worth of stress, and renewed my faith in logitech, as if i EVER doubted them <3333
Logitech... | Answered on Feb 26, 2010
Try un-pairing it from any other device and turn off bluetooth on any mobilefone in bletooth range. Then start discovery on ipod again.
Logitech... | Answered on Nov 04, 2009
Uninstall the software that came with your headset if indeed any did. Failing that, I 'm assuming this is a blutooth headset. Check your PC has latest bluetooth drivers and updates, reboot and reconnect your hardware
Logitech... | Answered on Oct 16, 2009
IF these headphones are wireless try recharging if they are not wireless you may have a shorted or blown speaker
Logitech... | Answered on Apr 26, 2009
Seems like you have a faulty transmitter unit. Try contacting logitech.
Logitech... | Answered on Mar 14, 2009
Logitech FreePulse Wireless  Consumer Headphones Logo
55 questions posted
Top Logitech Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
freepulse headphone pair anymore both
  • Audio Players & Recorders
