20 Most Recent
JVC HX-D77 Shelf System Questions & Answers
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Service schematics JVC-hxd77j
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 1100 posts to different brand TVs now. Pull up older posts there.
CD WONT EJECT
The gears are jammed, or the timing gear is out of sync, or a broken loading belt.
When i turn on the
try unplugging the speakers and then turning it on...if the protect goes away then you have a bad speaker or wiring...if it still displays the same message then the amplifier output may be blown and will need to get it repaired at a shop
I can't set the clock on my jvc hx-d77
You Can Only Do This With the Remote in the Following Steps.
1. Activate Clock Set Mode by Holding Down Shift and (6) then Shift (9)
2. Adjust the Hour by Pressing the Next or Fast Foward Button Under Group Skip,then Press Shift and (9) to Set the Hour.
3. Adjust the Minutes by Pressing the Next or Fast Foward Button Under Group Skip,Then Press Shift and (9) to Set the Minutes.
To Check Current Time while playing Press Shift while holding (7) down for 2 Seconds.
My jvc hxd77 won't play dvds
If they play cd´s then the motor disc spindle are in bad conditions loose their speed to read the dvd´s you need to replace him
JVC HX-D77 PROTECT!!!
MAKE SURE YOUR SPEAKER WIRES R CORRECTLY COLOR MOUNTED INTO OR CROSSED INTO THE STEREO
