20 Most Recent
Emerson iTone iE600BK Shelf System Questions & Answers
My iE600BK is no longer
The charging connector on the unit has gone bad. Check to see if the connector has any black charring on any of the contact. If so, unplug the unit from the mains and gently scrape your fingernail along the charring - this should remove the black char and allow it to work again.
Emerson HT-200B Digitial Stereo Amplifier no sound
Try to establish if it has power going to it. If not you are looking at the power supply. If it has power then you are looking the audio output. If you take off the top and see a device like in the picture then you can bet that has failed.
How to adjust buzzer volume on an Emerson smartset alarm clock, CKS1521?
Please check the bottom and back of your alarm clock for the buzzer volume option. If you can't find it, please refer to your manual. If this is not in the manual, then it might no be built into your product and you might need to trade-in for a new alarm clock that allows you to adjust the buzzer volume. Thank you.
