20 Most Recent Yamaha RX-V559 Receiver Questions & Answers
Receiver will not turn on Has no no way of signaling. Fuses correct replaced flip -flop TC4013 same situation as if no power
test current drain and then power supply out put
12/11/2014 12:23:16 PM • Yamaha RX-V559... • Answered on Dec 11, 2014
2answers
Receiver does not power up, was ok last night.
c3015 22n 600v i power supply
6/9/2013 12:04:57 PM • Yamaha RX-V559... • Answered on Jun 09, 2013
Hi, Rx-v559 power button doesnt power
If the power relay clicks. It may need the main power transformer. Primary of the transformer should be almost a short, if it is open-it's bad.
If no relay click. It could be main micro, stand by relay or the transistor that switches the relay on.
3/10/2011 11:08:29 PM • Yamaha RX-V559... • Answered on Mar 10, 2011
When I turn on the reciever, within seconds it
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
1/18/2011 9:06:35 PM • Yamaha RX-V559... • Answered on Jan 18, 2011
IS IT POSSIBLE TO CONNECT RX- V559 WITH BLUE RAY
Yes. Assuming you unnamed BD player has digital audio output that is compatible with one that's available to use on the Yamaha.
OTOH, the coaxial digital input CAN be shared if you use an RCA-Y cable and make sure only ONE of the shared inputs is turned on anytime you use it.
If the BD also has Component Video conenctors you could run them TO the Yamaha, too, but I would opt for the BEST video from the BD to go directly to your TV or monitor, even bypassing the AVR if necessary. The fewer intervening connections and conversions, the better.
12/23/2010 2:49:02 PM • Yamaha RX-V559... • Answered on Dec 23, 2010
How to install klipsch sub woofer to yamaha
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
3/3/2010 6:38:32 AM • Yamaha RX-V559... • Answered on Mar 03, 2010
2answers
Yamaha RX-V559 AV Receiver turns
Wild guess... Are you drawing power for these units from the back of the receiver? Plug them in somewhere else.
11/16/2009 2:12:09 AM • Yamaha RX-V559... • Answered on Nov 16, 2009
I dont have the remote
Hi, If there is Totally Black Display, It confirms that the LED bulb in the display has burned out. It might have 2 lead wires and a plug, which connects it to the power supply from the board. The part number must be mentioned on one of the lead wires. You can buy the part from Yamaha. Start at: http://www.yamaha.com/yec/customer/partinfo.htm Or, you may be able to find a generic replacement at a good electronics supply house; most bigger cities have them. They sell to retail, but most of their business is with independent repair shops. Even Radio Shack has LED diodes (they are not bulbs) and you might find one that is close enough to fit in with some Rube Goldberg adjustments or a little rubber cement to hold it in place. Sumitomo is a parts house in Japan that probably supplied the original part to Yamaha. They are a big company, but you could also try their website; unfortunately, I don't think they have an english version. They are a very big company and tracking down a supply for such a small item would be a huge task. Bottom line; I think the best solution is a generic LED diode that can be altered to fit the opening left by the old one. PS: They are not expensive. Maybe a few dollars. Maybe you can find one that will fit into the same holder so you can use the same cable and connector that was used by Yamaha. PS: If you are talking about the acutal lamp bulb that illuminates the main dial, you can always find replacements at places that sell various small bulbs such as auto supply houses, electronics parts houses, etc. Just make sure it is the right voltage rating and same pin connections, etc. If you don't know the voltage, you can buy a volt meter for about $9.99 at Radio Shack and measure it. But for LED diodes, they operate on current, not voltage, and they are all pretty much the same except for color and current rating (which controls how much illumination they give) Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
8/7/2009 10:56:22 PM • Yamaha RX-V559... • Answered on Aug 07, 2009
My Yamaha DC555 CD player has no sound. It was working but just quit sound
The laser that reads the disc's and the lens need to be replaced for your CD player.It cold be that the volume control has worn out and needs to be replaced.
1/21/2022 9:41:30 AM • Yamaha Audio... • Answered on Jan 21, 2022
2answers
How to solve midi connectivity issue with Yamaha keyboard?
You will need to send it in for repair is my assessment.
1/20/2022 12:17:22 PM • Yamaha Audio... • Answered on Jan 20, 2022
YAMAHA RX-V640 RECEIVER HOW DO I DO A FACTOR RESET please?
Question edited for clarity and spelling. In the link https://www.google.com/search?q=yamaha+rx-v640+factory+reset ..
1/18/2022 5:09:38 AM • Yamaha Audio... • Answered on Jan 18, 2022
How to connect Bose Series 5 Equalizer for 901 speakers to a Yamaha A 1080
Not all receivers will support an equalizer. If the receiver has a built in equalizer, another equalizer will not be supported.
1/17/2022 10:53:02 AM • Yamaha Audio... • Answered on Jan 17, 2022
How to hook up bose 901 to Yamaha RX-A1000 there is no pre out and input from receiver? Please help
There is a Pre Out. Use the FRONT terminals if your Bose are main front speakers. image-pbwfvm3vgp5yadzogpz1bykh-1-0.jpg
1/17/2022 5:54:28 AM • Yamaha Audio... • Answered on Jan 17, 2022
Unit won't turn on with remote
Can you turn it on with the switch
1/10/2022 9:32:38 PM • Yamaha Audio... • Answered on Jan 10, 2022
I have a subwoofer that has a problem, can anybody please help?
Hi Craig, I don't think this is something you can fix yourself, I'd try an electronic service center
1/9/2022 11:35:49 PM • Yamaha Audio... • Answered on Jan 09, 2022
Yamaha RX-530 Stereo Receiver, LCD panel is dead but everything else works perfectly.
SADLY YOU ARE ON YOUR OWN WITH IT .REPAIR SHOPS ARE HARD TO LOCATE
1/5/2022 1:37:38 AM • Yamaha Audio... • Answered on Jan 05, 2022
Yamaha rx-v379 receiver setup mode
You need another remote, just buy one! $23 on Amazon. https://www.google.com/search?q=Yamaha+rx-v379+replacement+remote ..
12/7/2021 3:04:25 PM • Yamaha Audio... • Answered on Dec 07, 2021
Yamaha RX-V559 Receiver Logo
14 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Muzahura Frank
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
receiver not power up ok last night
  • Audio Players & Recorders
