20 Most Recent Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. Upright Freezer w/ 6 Stor-Mor Door Shelves & Temperature Ala... Questions & Answers
Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
8/20/2010 9:14:26 PM • Amana Freezer... • Answered on Aug 20, 2010
The freezer is defrosting
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
5/21/2010 2:39:40 AM • Amana Freezer... • Answered on May 21, 2010
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
2/20/2010 5:37:05 PM • Amana Freezer... • Answered on Feb 20, 2010
2answers
Amana bottom freezer, all working OK, but very noisy freezer. How do I fix it?
There are a few potential causes of a noisy bottom freezer. Here are some things you can try to fix the problem:
  1. Check for frost buildup: Frost buildup can cause the freezer to become louder as it has to work harder to keep things frozen. To check for frost buildup, remove all items from the freezer and unplug the fridge. Then, use a hair dryer to melt any frost that has accumulated on the evaporator coils (usually located behind the back panel of the freezer).
  2. Check for loose parts: Some common sources of noise in a freezer are loose screws, washers, or other small parts. Check for any loose items and tighten them as needed.
  3. Check the evaporator fan: The evaporator fan is responsible for circulating air within the freezer. If the fan is not working properly, it can cause the freezer to become noisy. You can check the fan by removing the back panel of the freezer and listening for any unusual noises. If you suspect the fan is the problem, you may need to replace it.
  4. Check the compressor: The compressor is responsible for circulating refrigerant and cooling the freezer. If the compressor is malfunctioning, it can cause the freezer to become noisy. You can check the compressor by listening for any unusual noises or by checking the compressor with a multimeter. If you suspect the compressor is the problem, you may need to replace it.
If you are unable to fix the problem yourself, you may want to consider contacting a repair service. They will be able to diagnose and fix the issue more accurately.
1/4/2023 5:58:02 AM • Amana Freezers • Answered on Jan 04, 2023
AMANA UPRIGHT 11.8 Cu.Ft. deep freeze model# ESUF15HW. Only freeze at the bottom. food on top and middle shelves defrosted.
Check the seal. Close door on a piece of paper, see if seal grabs it
6/10/2019 1:36:58 PM • Amana Freezers • Answered on Jun 10, 2019
I have an amana refrigerator model #sxd22s2w. The
Seems like a clog somewhere calcium deposits
3/18/2019 9:15:43 AM • Amana Freezers • Answered on Mar 18, 2019
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
12/21/2015 6:17:02 AM • Amana Freezers • Answered on Dec 21, 2015
Can i wire a universal start relay on a aqf2013tew 04
No if you did work for few month
12/2/2014 12:35:54 AM • Amana Freezers • Answered on Dec 02, 2014
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes. You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
8/18/2014 9:47:26 PM • Amana Freezers • Answered on Aug 18, 2014
Frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
7/2/2014 4:57:02 PM • Amana Freezers • Answered on Jul 02, 2014
Freezers Logo
6 questions posted
Top Amana Freezers Experts
Gil Shultz
Tom Chichester
Lawrence Oravetz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
View Most Popular
Amana Freezers
  • Amana Freezers
Most Popular Question
amana freezer deepfreeze afu2067bw 19 6
  • Freezers
