20 Most Recent
Pacific Image PrimeFilm 3600u Film Scanner Questions & Answers
Is there a way this pf3600u will work with Windows 7?
Maybe; you would have to contact Pacific Image and see if they have a driver for Win7 for your unit. If they don't, you can try other drivers in the hope that you'll find one generic enough to make it work. You can also try running it in compatibility mode and load what drivers you do have. You have about a 50/50 chance of that working.
The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
The setup cd worksok for
Follow the link below to the manufatures website. The link will take you directly to the how to install the scanner and the driver download page. Follow the steps and you should be good.Hope this helps
I need a driver for
Windows
7 driver is available for download from the manufacturer website.
http://www.scanace.com/download/Cyb_X_SF.htm
If you are still having
problems, write back.
I have driver vsc101u.exe and
The current version of the driver for the PrimeFilm 3600U is 1.18c. You can download it from here:
http://www.scanace.com/support/Cyb_X_SF.htm . This is Win7 compatible.
The only vsc101u.exe for a scanner that I know is for the Umax scanner and is not compatible with Win7. (It was for Windows 98/Windows 2000)
I hope this helps.
(attempting to install the older driver will tell you fairly quickly if it is compatible. Most Win7 installs are 64-bit and the install routine will stop when it hits an unsigned driver (common for 32-bit software).)
I have windows7 and if
Tottigol --
Windows 7 driver is available for download from the manufacturer website. [http://www.scanace.com/download/Cyb_X_SF.htm]
If you are still having problems, write back. -- SWT
Scanner no longer communicates with the pc
Have your scanner turned on when you boot up your computer. Go to Programs, Acessories, Scanner and camera wizard, and it will give you directions if the scanner is not installed and recognized.
When I scan, all I get on my screen is a
its one of 2 things, either the drivers are not working properly, or you have a bad scanner assembly in your scanner.
I would recommend trying it on a windows XP to verify if the problem has to do with the drivers. you can also try contacting tech support for your product and see if they have heard any issues with vista and your scanner.
also, just in case make sure your in the right scanner mode, I had one person trying to scan paper, but the scanner was set to scan a negative
thanks di
