20 Most Recent Sharp Notevision XR-1S Slide Projector Questions & Answers
How do i get rid of the start up screen?
press enter. then press menu, right arrow once, down to setup guide, enter, and select off.
11/13/2009 2:17:43 PM • Sharp Notevision... • Answered on Nov 13, 2009
VIDEO DISPLAY PROBLEM FROM SHARP XR-1S LCD PROJECTOR
make sure the resolutions match. change it on the projector.
8/19/2009 6:22:08 PM • Sharp Notevision... • Answered on Aug 19, 2009
Which reset code do I use after adding developer to sharp ar-5726?
https://www.fixya.com/support/t14696300-reset_change_counter_sharp_ar_5726
3/24/2024 6:44:11 PM • Sharp Office... • Answered on Mar 24, 2024
Sharp UX-105 Fax Machine. I am looking for a copy of the manual please?
Question edited for clarity, turned around, added CAPS, added the word 'manual'.Duplicate question should have been deleted but Kardoc has answered, albeit wrong model. Refresh page to see your question when you press 'Post Question'.UX-105 in Russian, or 510 in English, which is probably close enough.https://www.google.com/search?q=sharp+ux-105+manual..
3/22/2024 12:08:51 AM • Sharp Office... • Answered on Mar 22, 2024
Manual for a Sharp UX-105 fax machine please?
https://www.manualslib.com/products/Sharp-Ux-510-641495.html
3/22/2024 12:00:07 AM • Sharp Office... • Answered on Mar 22, 2024
Sharp EL-1197PIII. How to load paper in it please?
Question edited for clarity. Remove the curl out of the paper by running 6" across the edge of a desk against the curl. With scissors, cut the end 1/2" straight. Then cut a 1/2" off both corners at 45 degrees. Push the paper in the slot and press the Feed Button. https://www.google.com/search?q=Sharp+EL-1197PIII.+How+to+load+paper My instructions are better than the video, but shows the process well. ..
3/17/2024 6:09:42 PM • Sharp Office... • Answered on Mar 17, 2024
2answers
AR 5516 sharp printer is showing dotted triangle symbol
Hello, Just replace toner cartridge or refill the toner container with refillable sharp ar202 refill bottle or sachet. Remember to remove waste toner if you are refilling, right.
3/17/2024 8:56:33 AM • Sharp Office... • Answered on Mar 17, 2024
Sharp Printer. How to fix error code L4-17
Error Codes > Sharp > MXC300W > Code L4-17
PrintCopy .info https://printcopy.info > brand=Sharp > code=L4-17 Code: L4-17; Description: Drum motor lock trouble; Causes: Drum motor trouble Connection trouble of the connector and the harness between MFPC PWB and the ... ..
3/16/2024 2:36:24 AM • Sharp Office... • Answered on Mar 16, 2024
How to find input at Sharp calculator?
SCIENTIFIC CALCULATOR OPERATION GUIDE
Sharp Global https://global.sharp > guidebook > documents > s... PDF Enters data for statistical calculations. Splits data used for dual-variable data input. (Used for dual-variable
3/13/2024 10:29:02 PM • Sharp Office... • Answered on Mar 13, 2024
3answers
System lock of my projector sharp 50s ,so how to unlock?
  1. Check the Remote: Make sure you have the remote control for the projector.
  2. Press the Menu Button: On the remote, press the "Menu" button.
  3. Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
  4. Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
  5. Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
  6. Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
2/28/2024 3:14:05 PM • Sharp Office... • Answered on Feb 28, 2024
Sharp EL-1197PIII printing nonsense after a jam.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it . Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism . you are looking for resources to properly align the gears. I found a few resources that might be helpful: Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link: SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib. Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link: Sharp EL-1197PIII User Manual online (mans.io). Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link: User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
1/23/2024 10:12:07 PM • Sharp Office... • Answered on Jan 23, 2024
My fridge won't stop beeping though door is closed
Posibllities to eliminate: 1) bad door seal 2) unbalanced fridge on floor 3) buildup of ice in fridge (defrost) 4) faulty door alarm. Check temp of fridge. Adjust up or down depending on whether too hot or too cold. Check for blocked air flow or too many items in freezer. But if the exterior is much warmer than usual, you may be looking for a repairman. The main circuit board might be blown Try a reset by unplugging it for 5 minutes, then plugging it back in. If a minor problem, this may stop the beeping.
1/16/2024 6:35:54 PM • Sharp Office... • Answered on Jan 16, 2024
Can I order a sensor for my sharp spc908
Maybe worth a look through this catalogue but I doubt spares are available; https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjizJ7-k92DAxWzQkEAHUqwDmQ4ChAWegQIBxAB&url=https%3A%2F%2Fwww.specialized.net%2Fmedia%2Fwysiwyg%2FSpecialized%2Fetc%2FSpring-2023-catalog.pdf&usg=AOvVaw2Z06h4GZtS13wC9OK0rLZl&opi=89978449
1/14/2024 3:08:34 PM • Sharp Office... • Answered on Jan 14, 2024
I need solution to code L4-51.
See error code list for this error Error Codes > Sharp > MX2310U > Code L4-51 (printcopy.info) See chapter 8 Troubleshooting of this manual for help MX-2310U Operation-Manual GB (sharp.eu)
1/5/2024 11:45:52 AM • Sharp Office... • Answered on Jan 05, 2024
2 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
get rid start up screen
  • Office Equipment & Supplies
