20 Most Recent Toshiba HD-A20 Questions & Answers
is this an lcd tv and does the backlight come on?if so the panel is defective which is very
common if the sound works.when you first turn
the tv momentarily you will see the picture for
a second then goes off,if the tv is doing this then the panel is defective.
Toshiba HD-A20 • Answered on May 27, 2013
Go into the menu options for the player, and switch to Bitstream! Not PCM
Toshiba HD-A20 • Answered on Mar 15, 2013
The Invalid Format message is generated when the processor can't recognize the disk. This can happen from only 2 causes:
1 - the laser sensor doesn't receives a correct signal. Not your case.
2 - the processor itself is malfunctioning. Since you can't finish the first step in troubleshooting it - the update of the firmware - it's clear that it's a hardware fault: the processor has indeed failed.
Unfortunately this is terminal: it can't be fixed so the only option would be to replace the mainboard but that's not an option - the board isn't sold as a separate part because it and the labor to install it would cost more than a new player.
Sorry, time for a new bluray/dvd player.
Toshiba HD-A20 • Answered on Jan 04, 2011
How are you connecting the HD-A20 to your audio device? The HDMI audio only supports PCM (Pulse-code modulation). There are other formatting issues that may be involved. So it is possible that your SD DVDs are in a supported format but not your HD DVDs. You might try a different audio connection (RCA audio or digital optical if you can) and see if the problem occurs.
What firmware do you have installed? http://www.tacp.toshiba.com/dvd/product.asp?model=hd-a20 at the Resources tab has three different Firmware update information links. (The first one is for version 4.0.) To download the firmware update, see the Customer Support drop down menu and Download Firmware.
I hope this helps.
Toshiba HD-A20 • Answered on Jun 28, 2010
I would unplug the HD-DVD from the wall power for 2 minutes and reboot. It sounds like a software hiccup and hopefully that will snap it out. Try another disc and double check the audio connections.
If rebooting doesn't solve, and it does this on all discs, the player is definitely malfunctioning, and you can open it up and look for bad capacitors, they will be bulged if bad
here is a pic:
let me know if you find bad caps, or if I can be of further assistance in any way. Thanks
Toshiba HD-A20 • Answered on Jun 10, 2010
Hi...
If it get get whacked with a surge , it may have crashed the power supply.
There might be a small glass fuse on the power supply too.
Have someone check that 1st. Otherwise it'll be cheaper to buy a new one
Toshiba HD-A20 • Answered on Apr 17, 2010
In some Toshiba models, only one output is active at a time. If the digital out is not active, the 'light' may not be visible.
Toshiba HD-A20 • Answered on Apr 02, 2010
try changing the cable, or use a different source.  It may just be the optics aren't functioning correctly.
Toshiba HD-A20 • Answered on Dec 12, 2009
the lens needs to be clean. Here is a link to learn how to do it, in your case, you don't need to open the case, just remove the disk and you will see it.
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Toshiba HD-A20 • Answered on Dec 05, 2009
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Toshiba HD-A20 • Answered on Nov 20, 2009
If this does this with all movies? and they are store bought originals and not scratched or have finger prints on the bottom of them? Your dvd player might need cleaning or the laser might be wearing out. Also ensure that you have the latest firmware update installed on it. You can install this update (ver 1.6) by simply pluggin in your ethernet cable to the back of your Player and follwing the steps on page 57 of your manual.
Hope This Helps
Turk
Toshiba HD-A20 • Answered on Oct 20, 2009
The most common causes,
1, bent or broken pins in scart lead.
2, faulty scart lead(internal wires broke)
3, mis-connected( audio out from dvd to audio out on tv.)
Just go through the list and if you have a known good scart lead, swap over to test.
Toshiba HD-A20 • Answered on Sep 04, 2009
what type of connection are you using?
HDMI or RCA
Toshiba HD-A20 • Answered on Aug 16, 2009
first of all ensure ur connection is all proper refer ur manual for how to set up ur dvd player but if this is a problem thats happened to u after using the player well for a long time.... then
Sounds to me that the eye is dirty or even bad try to run a dvd cleaning disk
In your player you can get them in most all stores such as walmart etc...
try to run it in the machine if it is real dirty you may have to run it a few times
if that doesnt help you can try to do it manually by taking the cover off
your player and then opening the dvd compartment to expose the eye and clean it with a cue tip
and alcohol lightly dip the cue tip and clean the lense off I have had to do that with dvd players and old playstations in the past and it worked fine. try the disk first though before taking anything apart
good luck this should work for you.
Thank you again for choosing FixYa.com for all your answers and please feel free to rate me for the answer i have provided.
Toshiba HD-A20 • Answered on Jul 18, 2009
This information can be found on the dish network website. (Just paste the link into your address bar and then bookmark the site for future reference) (http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml) in the frequently asked questions section.I hope this information helps you with your problem Toshiba DVD 616, 646, 647, 672, 735, 736, 750
Toshiba HD-A20 • Answered on Jun 06, 2009
Toshiba HD-A20 Logo
32 questions posted
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
hd dvd worki g
  • Televison & Video
