20 Most Recent Power Acoustik PTID-4003TV Car Video Player Questions & Answers
the rca jacks go to amplifiers and additional screens if you don't have those you don't need to use them .
Power Acoustik... • Answered on Mar 28, 2014
he has to buy a mounting kit and wiring harnest for your car so it will fit in right. when he buys that there will be instructions that come with it. i hope this helps
Power Acoustik... • Answered on Nov 30, 2013
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Power Acoustik... • Answered on Sep 08, 2013
It only supports MP4 format, so that is what you need to convert the videos to. Here are the specs: http://www.shopping.com/Power-Acoustik-PTID-4003TV/info
Power Acoustik... • Answered on Apr 25, 2012
sometimes you have to format the songs and then put them on the sd card but if you allready did that your sd card might be junk and make sure the sd card you bought is for music some arent
Power Acoustik... • Answered on Mar 13, 2012
You can connect ....
Power Acoustik... • Answered on Jun 09, 2010
what i did is i got a 4 prong relay. its gonna have numbers on it for certain wires. the 86 is for your remote wire and the 85 is for the parking brake wire. the other 2 are just grounds.this worked on mine so it should work for yours.
Power Acoustik... • Answered on Jun 05, 2010
the safety trigger i assume is the safety device to prevent you watching the DVD when you are driving?
This is done by connecting the safety device wire to the hand brake connection. thus preventing the device working until you apply the handbrake
Power Acoustik... • Answered on Apr 06, 2010
If you bought the correct cable it should work automatically. There are no settings. However, my 5300 was flakey right out of the box and I had to send it in for repair. It works perfectly now.
Power Acoustik... • Answered on Aug 06, 2009
check the owners manual for the stereo and see what file system format you need to use on the flash drive i know i had the same problem when i changed radios worked on my old one but plugged into the new stereo wouldnt load had to unload the music and reformat the flash drive and then reload the music onto it that took care of the problem. where you have tried two different usb drives would say not likely you have bad drives
Power Acoustik... • Answered on May 19, 2009
This might be related to your question, read through the answers.
http://www.fixya.com/support/t126992-bypass_parking_brake_switch_in_order
Power Acoustik PTID-4003TV Car Video Player Logo
37 questions posted
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Power Acoustik Car Audio & Video
Most Popular Question
cannot see video
  • Car Audio & Video
